hey guys
just wondering my fuel regulator it does not look right to me, shouldn't there be a hole for fuel to pass into it? i've got a pic below
help would be much appreciated
jace
(sposed to be drif86s not me)
hey guys
jace
4agte KE70 263.6whp
QR Sprint Circuit 1:02.9
QR Sprint Circuit 60.7 (turbo)
QR Clubman Circuit 1:06.41 (first outing NA)
QR Clubman Circuit 1:02.77 (turbo)
http://www.ae86drivingclub.com.au/fo...ustom-Stickers
full colour windscreen banners from $45!
Thats a fuel dampener!
Sprinter Veteran
which forms the banjo bolt that ataches the fuel feed line to the rail.
78's
sorri that was me who posted.. in the manual it says that this is the regulator?
that picture has it the wrong way around. the one labelled "pulsation dampener" with the vacuum hose coming out of it is the regulator. the one labelled "regulator" is in fact the pulsation dampener.
Gilly is correct.
ok cool thanksv.. now question is the regulator meant to have a hole for the banjo fitting because mine doesn't seem to have a hole for the banjo fitting
jace
As above, the pulsation damper is where the fuel enters the fuel rail from the fuel filter. This has the banjo fitting as the fuel entering here is at highish pressure. The fuel pressure regulator is at the rear of the fuel rail and fuel exiting this is at low pressure thus doesn't have a banjo fitting. Just a push fit with hose clamp.
