Results 1 to 8 of 8
Thread: fuel regulator
    Senior Member mrbigport's Avatar
    Craig
    Canungra
    hey guys
    just wondering my fuel regulator it does not look right to me, shouldn't there be a hole for fuel to pass into it? i've got a pic below
    help would be much appreciated
    cheers
    jace
    (sposed to be drif86s not me )
    4agte KE70 263.6whp
    QR Sprint Circuit 1:02.9
    QR Sprint Circuit 60.7 (turbo)
    QR Clubman Circuit 1:06.41 (first outing NA)
    QR Clubman Circuit 1:02.77 (turbo)
    http://www.ae86drivingclub.com.au/fo...ustom-Stickers
    full colour windscreen banners from $45!
    Apr 2011
    Steve
    Thats a fuel dampener!
    Sprinter Veteran
    Veteran slydar's Avatar
    Dimitri
    which forms the banjo bolt that ataches the fuel feed line to the rail.
    78's
    JP
    Eastside
    sorri that was me who posted.. in the manual it says that this is the regulator?
    Ferny Grove
    that picture has it the wrong way around. the one labelled "pulsation dampener" with the vacuum hose coming out of it is the regulator. the one labelled "regulator" is in fact the pulsation dampener.
    parrot
    Gilly is correct.
    JP
    Eastside
    ok cool thanksv .. now question is the regulator meant to have a hole for the banjo fitting because mine doesn't seem to have a hole for the banjo fitting
    cheers
    jace
    parrot
    As above, the pulsation damper is where the fuel enters the fuel rail from the fuel filter. This has the banjo fitting as the fuel entering here is at highish pressure. The fuel pressure regulator is at the rear of the fuel rail and fuel exiting this is at low pressure thus doesn't have a banjo fitting. Just a push fit with hose clamp.
  1. $$ 4ag fuel regulator $$
    By chucky in forum Cars or Parts Wanted
    Last Post: 9th July 2012, 08:16 AM
  2. Replies: 6
    Last Post: 29th May 2010, 10:36 AM
  3. Fuel pressure regulator
    By starni_boy in forum Car Parts For Sale
    Last Post: 2nd September 2008, 07:07 PM
  4. Fuel pressure regulator
    By Vezza in forum Technical - Questions
    Last Post: 16th August 2007, 08:24 AM
  5. WHAT FUEL PRESSURE REGULATOR
    By PRJECT in forum Technical - Questions
    Last Post: 3rd June 2006, 02:40 PM
