Results 1 to 10 of 15
Thread: few quetions for 20v
    getting 20v built at the moment ordering ross customs pistons in the next few days forged 20 thou oversize but not sure on comp what are the benifits/drawbacks of going to 11.5 just after different peoples opinions
    does a clutch to suit t-50 (200mm) bolt onto a 20v flywheel or do i need a 16vrwd fly??
    what are peoples views on haltech computers??
    Elite rthy's Avatar
    Leo
    Tulla
    how much did the ross pistons cost you? are they light?
    11.5:1 might require a fairly retarded ignition timing even with 98RON fuel
    212mm flywheels and 200mm cant share clutches. just use your standard 20V flywheel and clutch and you should be just fine
    Oldschool Member
    May 2005
    tadd
    nsw
    bh
    aus
    i'm using 20v flywheel, 20v pressure plate but friction plate from my old 4ac coz it had lots of meat in there when doing my engine swap lol. so now i'm not using all the surface on the flywheel lol. But it works fine I can de clutch under 3000rpm and still spin the wheels =).
    Nafe
    My advice.... DOn't go for Ross Racing pistons. A good amte of mine had some drama with them in his Nissan.....
    11.5:1 would be fine.
    Veteran slydar's Avatar
    Dimitri
    11.5 is fine.. you WILL be able to wind the ignition into to.. 4a's are very knock resistant due to the short rod ratio. also i guess youll be getting cams? if so yu can get away with higher cr as your effective CR will be lower due to the overlap.
    manual 20vs come with a 212 flywheel.
    16v are 200
    4ac ones are 200 too but theyre 6 bolt.
    id personally go for a 200mm if you have to buy one. 200s can hold the power of an NA engine easy, theyre a little lighter, and all the billet lightweight flywheels are 200mm, so if you wanna upgrade to one of those later, you wont have to get a new clutch.
    i wouldnt reccomend a haltech. we've had problems with them on 20vs before, not being able to read the CAS single causing a (severe) missfire/breakdown about 5000 rpm.
    78's
    May 2010
    Fletcher
    Wollongong
    I don't agree with going for the 200mm clutch over the 212mm one - you want the largest available clutch size as it will dissipate heat better and provide more torque handling for a given friction material and pressure plate stiffness (as there is more surface area).
    Lightened flywheels are available in both sizes (Toda, HKS, Xtreme, etc) so I woudn't use that as a factor for going for the smaller one. for most applications you want a 4-5kg flywheel for a street driven NA 4A - which all of the 212 mm flywheels are in this range.
    If you can, use the 212mm clutch/flywheel - Toyota upgraded it for a reason.
    havnt got them yet going today to faber in lakemba to order them $960 so dont know weight yet
    will be getting cams made up just need to decide on diff ratio they will only be mild cams though
    going to go with 11:1 comp spoke the guy doing the work and thats what he recomended unless i was using biger cams
    what computer would you recomend slydar or any one else
    thanks for the imput
    Nafe
    I'm in agreeance with dimitri on the flywheel. My car uses a lightened 200mm flywheel, and it has a 5AGE stroker engine with plenty of torque and have never had problems with my clutch.
    As for ECU, you can't really go past an Adaptronic or Razorback for quality and price/value for money.
    Dec 2005
    Adaptronic Ecu is apparently the best but it will set you back 1500 or so (Kizen sell these) this price is fitted though the price for the unit alone is $1000
    Haltech are a Good ECU, not as expensive as an adapronic form memory .. I havnt not sene one on a 20v so I dont know how it would go.
    Wolf 3D are proven and I know ofa few people runnign them on there 20v, best part is you can download maps off the net too
    Microtech what can I say ... everyone seems to run them so they must be fine
    Razor Back - great bang for buck ecu, they are good and cheap.
    in the end it comes down to what you want out of an ECU .. if you want a full crazy daily driver + track car and lots of tuning etc then I would go the adapronic / haltech
    If you want just a ecu to drive and give it the occasional once a month drift day thingo I would maybe consider one of the cheaper ecus
    hope that helps
    just my 2c
    Troy
    Baulkham hills
    Get an ECU that your trusted tuner can tune and recommend - no use buying ECU "X" coz it has a great rep but no one around you can tune it properly
    An ECU is only as good as its tune.
  1. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  2. T50 gear box, jdm 86 radiator, 20v head 20v bits :)
    By timpy in forum Car Parts For Sale
    Last Post: 12th June 2012, 07:22 PM
  3. Replies: 4
    Last Post: 12th September 2011, 12:12 PM
  4. Replies: 3
    Last Post: 17th March 2011, 12:47 AM
