False.
Rears yes but cut in half the car would be draggin its can around .
SO i heard you can get any model falcon springs
cut them in half and use them in the front and back of a ke70/ae71
true / false?
False.
for the Falcon springs in the rear, cut them down aiming for around 220 - 200mm free height (uncompressed height)
don't know about the front....
i wouldnt cut them in half just cut a couple of coils at a time. xf xe ea au falcon springs fit in the reare dont know about other models.
try searching
my old eb2 fairmont springs were the perfect fit front and back, dont know what crack you guys smoke
wheelfriends.wordpress.com
So you can use front or rear falcon springs from any of those models? Just cut a few cm off yes or no?
how heavy are they? if you cut the coils off do you know what the spring rate would be in kg/mm?
so i went about bought some falcon springs and they work!
king spring falcon lows in the front and rear
p/n are:
kfrl
kffr
got all four for $50![]()
dunno about the rates, but my front feels simmilar to ajps 8kg. I heated up on end though and knocked it level, handles pretty damn good
what is p/n, kfrl, kffr? that might be a dumb question i dunno, just done a 12hr drive.
what model falcon? did you use falcon fronts for the front and falcon rears for the rear? or fronts for the front and back, visa versa?
