Results 1 to 9 of 9
Thread: Trim adhesive.
    Senior Member xsoarerx's Avatar
    Logan City
    Im sticking on trim bits and Soarer badge to my mz11, anyone know of a good adhesive?
    Alex
    St Lucia
    I tried using one of those ones where you mix the 2 bits together and it makes a super strong adhesive. For me it was shit, it only works if its not defing gravity while its setting ie. dont use it on vertical or upsidedown surfaces, it wont work.
    Brad
    Central coast
    i dont know what the stuff we use at work. but it is sticky as hell! you get one bit on your leg and it wont come off for weeks!
    but i just get the 3M stuff in an aerosel can. seems to work very well.
    you just spray both surfaces and then let them tack dry then stick them both together.
    Logan City
    I think your thinking araldite adhesive where you mix the two different parts together flaming heads.
    Ill have a look for this 3m stuff… steroid chickens. Does it hold well? E.g. holding trim upside down on a boot lid?
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    sum heaps good stuff is sicaflex, sickaflex, sickerflex i dunno how to spell it.. the shit is nuts.. on my dads freinds boat there wer 2 plastic bits sicaflexed horizontally glued to the back of the boat..he had 2 get his wife and son to stand on them to get the glue to loosen a few mm so he could get a razor blade in there and cut it out... but anyways i dunno wher u get it but it mite not be good if u wanna get the interior peice off later on
    super glue.................?
    it super?
    alex
    wa
    new north
    Sikaflex is a good product but not really designed for trim peices (like interior trim stuff i assume)
    That 3M stuff is what you want, and it is basically a Contact Adhesive. Spray it onto both sides, let it tack dry, then push the 2 peices together and it bonds instantly, and dries even better. You just have to get it right first time, as moving things after sticking them together can be a messy task that can ruin the job.
    For the soarer badge, I assume its just a factory badge going onto the factory spot, some good double sided tape will work there, but dont use the normal newsagent stuff, its shit, have a look throught the 3M catalogue for thet one too.
    Logan City
    thats fair enough, ill have a look for that 3m stuff... the sikaflex sounds a bit much for what i want... haha.
    does the 3M double sideds tape come in a very thin type?
    thanks for all the repilys its a big help!
    Brad
    Central coast
    go the 3m stuff. i have retrimmed a hoodlining with it. also a couple of dashes. very strong stuff.
    isnt sikaflex more of a sealant? like urathene. it sticks aswell but it isnt really what it is designed for?
    i use the spray on stuff at work when i trim subwoofer boxes, works really well!
  1. JDM Interior Trim -Black- Some Exterior Trim - underdash etc
    By japan86 in forum Car Parts For Sale
    Last Post: 19th March 2013, 04:26 AM
  2. Removing A pillar trim
    By Admiral Ackbar in forum General Topics (No Technical Questions)
    Last Post: 6th November 2011, 05:02 PM
  3. AE71 internal trim
    By leon in forum Cars or Parts Wanted
    Last Post: 12th January 2010, 10:30 AM
  4. left 1/4 glass trim
    By BLIPAE86 in forum Cars or Parts Wanted
    Last Post: 25th November 2009, 02:32 PM
  5. Re-trim your seats
    By RolandGTV85 in forum General Topics (No Technical Questions)
    Last Post: 30th September 2009, 01:50 PM
