Results 1 to 10 of 12
Thread: 20v Waterpump leaking
    Senior Member mrbigport's Avatar
    Craig
    Canungra
    Heys, my conversion got finished about a week ago, but my waterpump off the silvertop is leaking pretty bad..
    I was told this wasnt too uncommon in imported engines, because the seals sit there for a while harden and crack when used again. I was told to just replace the darn thing, but thats about $160 down the drain and a fair wait. I was wondering if this has happened to any of you guys and what you guys suggest that i do?
    Should i juss fark what the mech told me and reseal the pump, or just grin and bear it and buy the brand new pump? Is there any other alternatives i have?
    Thanks,
    Ray
    4agte KE70 263.6whp
    QR Sprint Circuit 1:02.9
    QR Sprint Circuit 60.7 (turbo)
    QR Clubman Circuit 1:06.41 (first outing NA)
    QR Clubman Circuit 1:02.77 (turbo)
    http://www.ae86drivingclub.com.au/fo...ustom-Stickers
    full colour windscreen banners from $45!
    Dec 2005
    Replace.
    Or
    Use a 16v Pump.
    Jul 2009
    i have a spare new water pump i used for about a week till i got my rwd one... $50 plus postage???
    Craig
    Canungra
    Oh is there any complications when using a 16v pump? (read the offset is slightly different) and whats the difference between the fwd and rear wheel drive pump on the silvertop?
    May be interested matty shop, just checkin my alternatives..
    4agte KE70 263.6whp
    Nov 2005
    they sell new 16v water pumps on ebay for about $60
    You could reseal it but it might start leaking anytime soon depending on how flat and straight the part line surfaces are, new replacement parts are always good especially when it comes to your cooling system!
    RWD pumps have the thermostat housing bolted on to it but still has the same bolt pattern when for the 20v, I used my 4ac pump for a while... im sure the 16v pump fit can anyone confirm this?
    Sep 2006
    so 4ac pump will bolt straight up to silvertop? asking casue my water pump fucked out today arg! need of one asap
    Nov 2005
    yep
    Dec 2005
    But they have run a different pully.
    And even if you swap to a 20v pully it isnt going to line up correct.
    Please correct me if im wrong anyone.
    May 2010
    Fletcher
    Wollongong
    the 16V FWD pump front half is the same offset as the 20V front half. I am currently running a 4AC rear thermo housing and a 16V FWD pump using a 20V crank pulley and alternator and it all lines up perfectly. There are differences in the bits that the cam covers line up with, but who cares.
    DONT use the front half of a RWD pump unless you use the corresponding RWD crank pulley.
    I would simply go and buy a new water pump, resealing them is a waste of time for the sake of $60 (16V FWD ebay) or $150 (Genuine 20V) pump when you have buggerise around pulling the Timing belt, etc. off to get at it.
    Oldschool Member
    Aug 2005
    my pump recently started to leak after not driving the car very often... it is a 4age rwd pump. does this mean I can get a new fwd 4age pump and make it close enough to rwd with what I have got? (actually just thinking about it, i might be running a 4ac pump currently.)
  1. diff leaking
    By johl in forum Technical - Questions
    Last Post: 28th February 2009, 09:25 AM
  2. Leaking Diff
    By Dave in forum Technical - Questions
    Last Post: 10th January 2009, 05:01 AM
  3. leaking Petrol
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 1st October 2008, 09:24 PM
  4. 4ac waterpump same as 4age rwd waterpump?
    By simonster in forum Technical - Questions
    Last Post: 25th October 2007, 10:11 PM
  5. FS: 4AC Altenator (Re-Cond), 20V Waterpump, ADM Grille
    By Oly AE86 in forum Car Parts For Sale
    Last Post: 13th September 2007, 07:07 PM
