Heres the specs
1983 TOYOTA AE86 SPRINTER ( ADM )
ORGINAL SPECS
4A-C 1.6 8-valve SOHC Carb 78 Hp (58 kw)
T50 Gearbox ( ADM )
Vented Disc Brakes ( Front )
Drum Brakes ( Rear )
TODAYS SPECS
( Converted to Jap Spec )
ENGINE
4AGE 1.6 16V Blue Top 115 Hp( 86kw )
Cam Covers ( Polished )
HKS Cam Gears
HKS Cams (256 / 265)
HKS 4 1 Extractor
KOYO Aluminium Twin Core Radiator
Samco Red Silicone Coolant Hoses
Turbosmart Red Silicone Vacuum Hoses
Turbosmart Red Silicone Radiator Overflow Hoses
TRD Spark Plug Leads
K & N Pod Filter
Custom Intake Pipe ( Polished )
Custom Cold Air Partition ( Polished )
TRD Oil Cap
TRD Radiator Cap
Aluminium Sump Guard
Custom Reservoir Socks ( Power Steering, Brake, Clutch )
DRIVELINE
T50 Gearbox ( JDM )
TRD Short Shifter
TRD Lighten Flywheel (5Kg)
Custom Brass Button Clutch
Custom Pressure Plate
Tailshaft ( JDM )
T-Series Differential ( JDM )
TRD 4.3 Crown Wheel and Pinion
TRD 2way LSD
Pan Hard Rod Adjustable
Power Steering Set-up ( JDM )
Fuel Tank ( JDM )
Modified Fuel Lines
Vented Disc Brakes ( JDM ) All-round
SUSPENSION
TRD Bushes
Coilover's (Converted Struts)
Cusco Sleeve Kit
8Kg TRD Sleeved Springs
4way TRD Adjustable Shocks
Cusco Camber Plates
Cusco Lower Control Arms
Cusco Strut Brace
Cusco 24mm Stabilizer Bar
6Kg TRD Springs
8way TRD Adjustable Shocks
Cusco Strut Brace
Cusco 20mm Stabilizer Bar (Cusco 18mm also)
Cusco N1 4-Link System
Cusco Adjustable Lateral Rod
WHEELS
16" x 6.5 SSR
205/45/R16
INSIDE
Interior Seats ( JDM )
Interior Panels ( JDM )
Dash ( JDM )
Instrument Cluster ( JDM )
Centre Console ( JDM )
Climate Control
Electric Side Mirrors
Bride Drivers Seat
Nardi Steering Wheel
100mm Steering Wheel Spacer
Full Alarm System
Central Door Locking
OUTSIDE
Trueno Front End
Redline Tail Lights
Side Skirts
2 Tone Black and Grey Paint
Strobe Kit ( Park Lights )
Private Licence Plate
Work is still ongoing with this car
and heres one from the PAS Western Salon Show 4th & 5th Nov 2006
