Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: how heavy should the steering feel? and when does power kick in on a 4age?
  1. #11
    well i have a 4age 100kw and it kicks in around 4000-4500rpm
    my old one was a 100kw bottem end with a 86kwhead and the power could come in around 3000-3500rpm
    y do they have diffrent rev ranges??
  2. #12
    stefan
    vic
    eastern suburbs
    its interesting how small displacements work, i was too used to a 2.2L but after a few days of driving the sprinter im getting used to having to keep the revs up
  3. #13
    Jul 2009
    mine is actually lighter than pwr steering in my magna!!
  4. #14
    Troy
    Baulkham hills
    ..basically for a smaller engine to make the same power as a larger engine, it needs to rev more! Power = rpm x torque in very basic terms. So larger engine with more torque does not need to rev as much as a smaller engine with less torque to make the same power
  5. #15
    Senior Member Micknofx's Avatar
    Mick
    sa
    adelaide
    Aus
    my bigport with tvis removed starts at around 4500 and is really on song by 5500 peaking at about 6600.
  6. #16
    Jul 2009
    my modded smallport starts a nice torque curve at a suprising 3000rpm !!! yes you heard right.. some people say port work doesn't do much.. helped out in the torque department!
  7. #17
    Senior Member riceburner's Avatar
    Different compression, slightly different cams + the 100kw doesnt have tvis and is a small port. Ecu tuning would also play a roll in why the 2 motors are so different. Different inlet manifold, different exhaust manifold would also cause the difference you speak of.
    But im betting there are more technical reason behind it.
    And then you get the odd freak motor, a motor that you can put thru hell day in day out, and still lives to fight another day.
    Insert witty comment here....
  1. JDM T50 Conversion + RWD 4AGE Power steering!
    By marvis in forum Car Parts For Sale
    Last Post: 12th June 2012, 12:45 PM
  2. heavy steering
    By ae86 in forum Technical - Questions
    Last Post: 16th December 2010, 12:35 AM
  3. heavy steering
    By ae86ln in forum Technical - Questions
    Last Post: 17th April 2010, 11:37 AM
  4. heavy steering
    By redsprinter in forum Technical - Questions
    Last Post: 20th November 2009, 09:18 PM
  5. How to make the steering feel lighter
    By slydar in forum Technical - Questions
    Last Post: 2nd January 2006, 02:43 PM
