Page 1 of 20 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 195
Thread: still have this starting problem
    alrightt... when i turn the key to start the motor sometimes it starts advanced or retarted and sometimes it also cranks over and just stops like the battery is dead....
    got no idea what it is.. can someone please help???
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    make sure your vacuum advance leads are all properly attached and not blocked. also make sure there is no corosion or anything out of the ordinary on you battery and alternator leads. get your ignition timing checked get it set a few degrees advanced.
    that might be the case anyway
    Senior Member riceburner's Avatar
    Once you have tried all other options given (check battery terminals etc etc), try the Key Way on the crank.
    My bet is it slipping and causing advanced/retarded starting, as in the crank is turning but key way slipping is stopping the timing belt from turning, and cause it out of alignment it wont continue to run.
    Given on what you discribed i would start there.
    Oh and if battery problems are present, unlikely that would cause retarded/advanced starting. But it wont hurt to look a every point of the starting area.
    does the motor sound chocked when cranking.
    Insert witty comment here....
    Jun 2009
    Michael
    Whats advanced or retarded? The timing? The keyway cant slip, if it does your gona be having more than starting issues.
    If its happening when the motor is hot it could just be excessive resistance caused by the heat.
    i have checked battery earth leads etc... timing belt is brand new its not slipping, the dizzy is set perfect
    it could be the computer sending wrong spark
    Um yes the key way can and it will slip if its buggered. New timing belt doesnt mean the keyway wont slip. Does the motor work at all, like is it only hard to start but runs fine otherwise!
    Computer is only as smart as you tell it to be and even then it has restrictions. ECU isnt sending the wrong spark unless your forcing it too.
    Zac
    Sunnybanku
    does it sometimes backfire when it eventually starts?
    yes the motor runs fine when it starts proply... sometime is backfires and also reverse starts
    its mostly does it when its hot....2day was the worst in this hot weather does any1 know what this is?? its snapping me
    could be the coil or something similiar??
    Tell me how a starter motor allows a reverse start.
  1. wire starting problem
    By evil86 in forum Technical - Questions
    Last Post: 19th April 2010, 12:43 AM
  2. problem starting
    By noobae86 in forum Technical - Questions
    Last Post: 14th February 2007, 08:49 PM
  3. starting problem
    By breno in forum Technical - Questions
    Last Post: 18th July 2006, 09:18 PM
