Results 1 to 10 of 13
Thread: Polishin intake manifold
    hey guys. im thinkin of polishin my intake manifold
    has any1 got this done before?
    if so where and how much was it?
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I got some steel wool onto mine and it came up pretty good. I had to use this really shite stuff though. So I'm yet to get some more. Give that a whirl before you take it to someone else to do it. Just get some steel wool and water and screw round with it for 15 minutes, you'll notice the difference.
    lol i have kinda tried on my old small port intake but it didn't turn out that good
    it takes so long to do it
    Mar 2005
    wire brush on a drill gets em shiny... prob not as shiny as you would want though.......
    Troy
    Baulkham hills
    Its quite easy to do but takes a lot of time and sore fingers! Personally I would start with some medium grade sandpaper to start smoothing over any rough bits, use a file to clean up any sharp edges or daggy bits, cast lines etc. Then move to finer sandpaper until you get down to very fine wet/dry. Then get some Autosol or another brand of metal polish, a bunch of wrags and start polishing!!
    I've polished a few cast alloy parts this way and they come up pretty well. The more effort and time you put into it the better the result.
    oh ok thanks pplz
    i will b doin it when i have some time off from work
    do u think i should a orbital sander?
    or should i hand sand it?
    cheers shell
    Highlife said it........wet/dry black sandpaper in various grits, then either autosol or get a polishing compound kit from bunnings, and get busy. Quicker but you'll have to fork $25 for the kit. Don't be a slack-ass! do it yourself!
    PS^^^^that is an attachment for a drill, so don't buy it if you don't have a drill! or get a XU1 cord hammer drill for about 15 bucks while you're at it.....and get a sausage in bread too.
    Troy
    Baulkham hills
    Hand sanding is better for intricate bits where you need to get in and around curves etc. Large flat areas you could probably use an orbital sander but I think hand sanding is better.
    Julz01
    Yea as highlife said use wet and dry and work your way down, also once you have done a fair bit of sanding wash the surface and use some metal polish on it , like autosole or the mx meguires stuff. It works a treat and will polish up nicly. I polished the outer lips of my second set of wheels and they have come up pretty good with this method.
    only thing will polishing it is that you need to keep polishing the surface with the metal polish to keep it nice and clean
  1. Replies: 4
    Last Post: 1st September 2010, 01:47 PM
  2. WTB Intake manifold
    By trikzlane in forum Cars or Parts Wanted
    Last Post: 12th September 2009, 02:25 PM
  3. Intake Manifold Dimensions
    By The_81 in forum Technical - Questions
    Last Post: 28th August 2009, 01:16 AM
  4. RWD Intake Manifold and FWD Intake manifold
    By omygtr in forum Car Parts For Sale
    Last Post: 17th April 2009, 07:13 PM
  5. WTB:RWD 4age intake manifold, exhaust manifold
    By djscheppy in forum Cars or Parts Wanted
    Last Post: 8th June 2008, 06:39 PM
