Results 1 to 10 of 18
Thread: 4age enigne swap to a KE70 whats needed ?
    Paul
    West
    4age enigne swap to a KE70 whats needed ? how much whould it cost ? thanks
    Dave
    question 1- lots of things
    questino 2- about this much |-----------------| (note not to scale)
    on a serious note, look around this site, stacks of info, rollaclub is also good
    - Blaise Pascal
    Paul
    West
    umm ok
    Rob
    Moorabbin
    you will need
    1x 4age
    1x ke70
    and most of the bits from an ae71 (pedal set, t50, hydro clutch conversion, tacho dash (if you want) etc, not hard to do been done a million times before)
    have fun
    Mar 2010
    Rory
    To start you off...
    R
    Ferny Grove
    AE86 or AE71 engine crossmember
    AE71 gearbox x member (86 one can be used)
    AE71 pedal box
    AE71 or AE86 clutch master cylinder
    AE71 or AE86 solid clutch line from master to slave, and rubber hose
    AE71 or AE86 rubber engine mounts
    AE71 or AE86 steel engine brackets
    AE71 or AE86 gearbox stays (link box to block)
    AE71 tailshaft if keeping the ke70 borg diff
    AE86 tailshaft if using S series
    AE86 tailshaft with T18 back half if using T series diff
    T50 gear box
    obviously a 4AGE of some sorts JDM being easier, ADM FWD being a little trickier but no big deal.
    thats just what you need to get the engine in there, you will also need
    modify tank pickup with fuel pump, plus mod top tank plate with a 8mm fitting for fuel feed.
    fuel hose (injection spec)
    loom to suit, either modded AE82 loom if using a bigport, modded AE92 loom if using a smallport, or a slightly less modified JDM loom again if you are using a bigport.
    ^^^ that would have got me like 4,908,876 rep points on toymods
    as for cost, depends on how much you do your self and how cheap you can find AE71 parts
    best base would be an AE71 as you have most of the shit you need. honestly if you live the KE70 front buy and AE71 and front panels of a 70 it works out cheaper than trying to find all the 71 parts required.
    man i'm so making this a tech article.
    Paul
    West
    U legend thanks 4 the help should be getting the car end of this week striping the hole thing down 2 the shell then painting thanks again
    Paul
    West
    so should i get a donor car or buy the parts seperate
    Ferny Grove
    if you can find a complete ae71 get it. if not just ry getting parts seperate, just depends what you find i suppose
    Paul
    West
    and the noobest qestion which is better big port or small
  1. Whats needed for T series diff into ADM AE86
    By BARWICK in forum Technical - Questions
    Last Post: 30th September 2011, 07:14 AM
  2. w5* conversion and whats needed
    By stylz in forum Technical - Questions
    Last Post: 5th August 2009, 05:01 PM
  3. whats needed to run LT10s on turbo smallport?
    By Nic19 in forum Technical - Questions
    Last Post: 2nd May 2009, 01:35 PM
  4. Drift Practice, Whats needed?
    By Eircamae86 in forum The Drift Channel
    Last Post: 19th January 2009, 12:54 PM
  5. Whats Needed To Turbo A 20v
    By RB20DET_Silvia in forum Technical - Questions
    Last Post: 12th October 2006, 02:10 PM
