i will be buying a new ae86 from japan in around january or february. i will more than likely be using a 7a20 for the engine, and therefore will not really require any parts from the engine or its supporting systems. this means i will have for sale an entire engine package, i will also be able to offer things like the body loom and dash loom (aswell as matching cluster) meaning you will be able to fully convert your adm 86 to jdm spec (front half anyway) this also means that basically anyone with some mechanical aptitude should be able to complete the conversion themselves without needing any help from a workshop, there will also be no wiring required, as you will have all 3 major looms from the same car, all fully compatible.
it will most likely be a trueno, simply because i am shopping exclusively for a coupe, and trueno coupes are more common than levins. i actually much prefer levins though, so as long as the person who is interested in the nose has levin parts to swap, a trueno nose will be available too.
obviously this is somewhat of a complex deal that will require some discussion before anyone commits. but im just putting it out there so that hopefully the right persons sees this and the deal can be mutually beneficial.
i will be looking at wanting around $1500-1800 for the engine package, and around $800-1200 for the trueno nose. price variance is due to unforseeable details such as accessories that come with the motor (light flywheel, cams, headers ect, which it is not unlikely to have) condition of the nose (and the nose to be swapped) and whether it is zenki/kouki/kitted.
reply here or PM if interested.
