Results 1 to 10 of 11
Thread: rust in the coolent
    Nov 2005
    When I got my 20v, it was clean as with red coolent inside
    then i switched from red coolent to green as it was more readily available to buy
    I mixed it with distilled water at first.... then toped it up with tap water (ran out of distilled)
    after a few weeks when i opened the cooling system the water wasn't green it came out brown as... and there was rusty gunk everywhere.
    What did i do wrong?
    Red and green coolant should not be mixed (I have heard). If you change from one to the other you need to flush the system with straight water before switching.
    But to answer your question, no tap water wont have caused this problem.
    Hard to say what the problem is without a closer inspection.
    Poh
    Bevo
    yup switching from red to green with no flush= corrossion
    best flush it asap, u dont wanna block your acilliries in the motor causing it to overheat or crack
    flush the system, drive it for a couple of days, flush it again, drive a couple of days....keep doing that until you are able to drive the car for a week or so without the coolant going brown.
    it just sounds like your engine needs a bit of a clean mate
    Nov 2005
    thanks....
    flush flush flush
    red coolant is meant to a little different in composition, they use on originally track cars so if they have a smash and drop fluid its not a slipperry as the green stuff....what i was told a while back
    Nafe
    Genuine toyota coolant isred. Buy a whole lot ad do a good flush
    Rob
    Moorabbin
    the corrosion inhibitors can have a chemical reaction! this is what has happened, drain your system and flush and refill with water ONLY, dont waste coolant, flush with water only, then when it is clean, then re fill with red only...cheers
    Jul 2009
    go to your local toyota and get a 4L bottle of genuine coolant.. after you have flushed it with a good quality radiator flush..
    hasn't this topic been coverd a few times or something very very similar in the last few weeks?
    can't say it enough times.. it is some of the best stuff i have ever used!
    Jul 2009
    P.S. dave - you look like a stooge in the drift battle magazine! nice haircaut man! got the whole all american rejects thing goin... lol ! jokes.. i liked the pics!
  1. throttle body coolent setup
    By 4ag te72 in forum Cars or Parts Wanted
    Last Post: 3rd March 2011, 12:13 AM
  2. Wanted: rust free or minimal rust ae86 body shell rolling or not.
    By buster86 in forum Cars or Parts Wanted
    Last Post: 6th January 2011, 11:02 PM
  3. Rust
    By 86coupe in forum General Topics (No Technical Questions)
    Last Post: 14th October 2009, 06:11 PM
  4. rust
    By stylz in forum Technical - Questions
    Last Post: 20th May 2006, 01:51 AM
  5. where is the rust?
    By emilmh in forum General Topics (No Technical Questions)
    Last Post: 7th June 2005, 07:55 PM
