i just got the long hose going to the bak of the motor and a flexi hose going bak to the radiator
Hey all,
I've got an AE101 4AGZE (that's going turbo, yewwww), and it's currently got the FWD water pump setup. Is there a problem with me just getting the long pipe that runs out of the back of it mandell bent to go to the front of the block? Or do I need to hunt down and purchase a RWD water pump? If I can't mandell bend it, can I just cut it short and get a moulded radiator u-bend?
Cooly cooly anyone?
The Phoenix; In the build since 10/06!
:: 4A-GTE / GT2560R / W58 / TRD 2-Way / F Series Diff / Microtech LT10S / AJPS Supplied Suspension ::
Where will it stop? Will it ever be finished? How will it go? Why am I not wearing any pants?
Sweet. I was worried that there was something magical about the RWD 4AGE water pumps and I had to have one. This makes me happy.![]()
you can have a non dodgy RWD setup without a rwd pump, you just use an external thermostat. If you must I have one of those rear pipe plates for sale.
30kw club
