I bought the line off an AE82 twin cam new from Toyota years ago very cheaply and bent it up to suit the floor pan which is a prick of a job. At least it has the correct fittings each end if using a factory pump and filter.
If I was doing it now, I would cut the fittings off each end of the fuel line of an EFI Toyota at the wreckers (pickapart is full of EFI Camry's) and buy a length of 8mm pipe and make one up to suit.
