1 should be the map sensor?
I HAVE PLUGED IN ALL THE PLUGS ON MY AE82 4AGE ENGINE AND JDM MANIFOLD. THE ENGINE RUNS ONLY ON AEROSTART HAVENT LOOKED INTO Y THE INJECTORS ARNT WORKING BUT I FOUND 2 SPARE PLUGS THAT REACH TO BEHIND THE PLENUM CHAMBER, LOOKS LIKE THEY MAY GO 2 SUMMIN ON THE FIREWALL, ON THE WIRING LOOM AND WONDERED IF THERE IS SPOSE TO BE AN INJECTOR MODULE OR SUMMIN? GOT A YELLOW CIRCULAR PLUG WITH 3 PINS AND A BROWN RECTANGLE 2 PIN PLUG.?
look on club4AG for the wiring pinouts and trace the wire colours.
or take a picture and I will have a look.
damn do 4ags have a map sensor? thatd be the yellow plug im guessing
Yes, almost certainly the yellow is the MAP sensor. The brown will be the start injector time switch which is mounted in the sensor block on the very rear of the cylinder head. The one that has the two sensors. The other sensor on this block has a green plug
adm ae82 have 2 brown plugs, 1 is mounted at the rear of the block (as above) and the other is to the rear water housing for fwd
pictorial answer for you my friend.
yellow plug is for the map sensor as you now know, pic shows where the brown plug goes (like Parrot says)
picture is of my JDM loom so should be the same as what you have.
you can use an AE82 map sensor you will just have to change plugs, as only JDM MAP sensor use the circle plug. if need be i know someone who has a few JDM Map sensors if you want a JDM one drop me a pm and i'll suss it out for you.
MAP sensor does bolt to the firewall i just put there so it was in the picture![]()
cools cheers lads got the yellow 1 figured now but what does the brown 1 go 2 exaclty cos the rear water housing already has the green and brown plugs on it. ive got a 4ag and a a 4agze and both running am computers this is the first sotck comp 4ag ive dun.
