Results 11 to 20 of 24
Thread: JDM 86 ENGINE BAY WIRING LOOM
  1. #11
    Elite rthy's Avatar
    Leo
    Tulla
    if ur running the jdm water pump setup then u wouldnt have the adm fwd rear water housing?
    try running it with out
  2. #12
    Ferny Grove
    thats the only brown plug i have on mine, and there are no other "spare" plugs to speak of.
    any chance you can get a pic up?
    EDIT: just realised its an AE82 engine. do what rthy said
  3. #13
    cheers heres a brain teaser. does the ae82 map sensor have 3 wires aswell as the jdm86
  4. #14
    Elite rthy's Avatar
    Leo
    Tulla
    yea i have a ae82 loom and running with out the rear water housing (plug not in use)
    all bigport map sensors should be the same?
  5. #15
    the maps are the same plug,picked one up from recker off a twinky and it plugged in
  6. #16
    parrot
    Bigport map sensors are identical, other than the bracket that bolts them to the body. If you use an AE82 sensor you simply need to make a right angle bracket to bolt it where it is meant to go on an AE86. Plug is identical
  7. #17
    Ferny Grove
    hmm my engine apparantly had an ae82 map sensor as it was running a ae82 loom in a Ke70. i have a JDM loom and had to get a JDM map sensor as the plugs were different
  8. #18
    wait...sorry i ended up using a ae82 loom so thats why it plugged up easy for me. I am an idiot , heard it here first
  9. #19
    but my plug looks exactly the same as gilly's one.
    ziptie ftw
  10. #20
    just rang wreckers Ae82 same as 86 cheers for all help lads found theres spose to be a injector main power wire so maybe that aswel be the problem
  1. WTB ADM AE86 ENGINE BAY WIRING LOOM+ 20v .5mm TRD HG
    By FAST EDDIE in forum Cars or Parts Wanted
    Last Post: 16th June 2011, 01:55 AM
  2. Neatening up the engine bay Wiring
    By rgeorgiou in forum KE70 / AE71 Owners Forums
    Last Post: 12th May 2009, 08:49 PM
  3. WTB JDM engine bay loom + rear coupe parts
    By omygtr in forum Cars or Parts Wanted
    Last Post: 11th February 2009, 12:44 PM
  4. fuses in 86 engine bay
    By mini bus in forum Technical - Questions
    Last Post: 19th January 2009, 11:42 PM
  5. Swaping ADM Wiring Loom with JDM Loom
    By joshcris in forum Technical - Questions
    Last Post: 20th September 2007, 03:18 PM
