What colour is the cold start injector plug meant to be???
Is it possible you have accidently swapped the cold start with a injector plug.
I bet a pic would have this solved in seconds.
AE86 on the left, AE82 on the right.
The brown plug at the bottom right is for the cold start injector time switch. If it doesn't look like that, you will have to put a pic up. Yes there is an injector main power wire but that doesn't have a plug in it.
[attachment=9315:attachment]
Insert witty comment here....
my cold start injector plug (JDM LOOM) is black
The cold start injector plug is black, but the cold start injector plug is not the same as the cold start injector time switch sensor plug (which is brown as per the photo above)!
Cold start injector is situated in the main body of the plenum.
The cold start injector time switch sensor (i.e. the thing that signals to the ECU how hot the engine is and thus how long the cold start injector stays on for is located on that sensor block on the back of the head.
