Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: JDM 86 ENGINE BAY WIRING LOOM
    I HAVE PLUGED IN ALL THE PLUGS ON MY AE82 4AGE ENGINE AND JDM MANIFOLD. THE ENGINE RUNS ONLY ON AEROSTART HAVENT LOOKED INTO Y THE INJECTORS ARNT WORKING BUT I FOUND 2 SPARE PLUGS THAT REACH TO BEHIND THE PLENUM CHAMBER, LOOKS LIKE THEY MAY GO 2 SUMMIN ON THE FIREWALL, ON THE WIRING LOOM AND WONDERED IF THERE IS SPOSE TO BE AN INJECTOR MODULE OR SUMMIN? GOT A YELLOW CIRCULAR PLUG WITH 3 PINS AND A BROWN RECTANGLE 2 PIN PLUG.?
    Elite rthy's Avatar
    Leo
    Tulla
    1 should be the map sensor?
    30kw club
    May 2010
    Fletcher
    Wollongong
    look on club4AG for the wiring pinouts and trace the wire colours.
    parrot
    or take a picture and I will have a look.
    damn do 4ags have a map sensor? thatd be the yellow plug im guessing
    parrot
    Yes, almost certainly the yellow is the MAP sensor. The brown will be the start injector time switch which is mounted in the sensor block on the very rear of the cylinder head. The one that has the two sensors. The other sensor on this block has a green plug
    Elite rthy's Avatar
    Leo
    Tulla
    adm ae82 have 2 brown plugs, 1 is mounted at the rear of the block (as above) and the other is to the rear water housing for fwd
    30kw club
    Ferny Grove
    pictorial answer for you my friend.
    yellow plug is for the map sensor as you now know, pic shows where the brown plug goes (like Parrot says)
    picture is of my JDM loom so should be the same as what you have.
    you can use an AE82 map sensor you will just have to change plugs, as only JDM MAP sensor use the circle plug. if need be i know someone who has a few JDM Map sensors if you want a JDM one drop me a pm and i'll suss it out for you.
    Ferny Grove
    MAP sensor does bolt to the firewall i just put there so it was in the picture
    cools cheers lads got the yellow 1 figured now but what does the brown 1 go 2 exaclty cos the rear water housing already has the green and brown plugs on it. ive got a 4ag and a a 4agze and both running am computers this is the first sotck comp 4ag ive dun.
  1. WTB ADM AE86 ENGINE BAY WIRING LOOM+ 20v .5mm TRD HG
    By FAST EDDIE in forum Cars or Parts Wanted
    Last Post: 16th June 2011, 01:55 AM
  2. Neatening up the engine bay Wiring
    By rgeorgiou in forum KE70 / AE71 Owners Forums
    Last Post: 12th May 2009, 08:49 PM
  3. WTB JDM engine bay loom + rear coupe parts
    By omygtr in forum Cars or Parts Wanted
    Last Post: 11th February 2009, 12:44 PM
  4. fuses in 86 engine bay
    By mini bus in forum Technical - Questions
    Last Post: 19th January 2009, 11:42 PM
  5. Swaping ADM Wiring Loom with JDM Loom
    By joshcris in forum Technical - Questions
    Last Post: 20th September 2007, 03:18 PM
