Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: JDM 86 ENGINE BAY WIRING LOOM
  1. #21
    parrot
    AE86 on the left, AE82 on the right.
    The brown plug at the bottom right is for the cold start injector time switch. If it doesn't look like that, you will have to put a pic up. Yes there is an injector main power wire but that doesn't have a plug in it.
    [attachment=9315:attachment]
  2. #22
    What colour is the cold start injector plug meant to be???
    Is it possible you have accidently swapped the cold start with a injector plug.
    I bet a pic would have this solved in seconds.
    Insert witty comment here....
  3. #23
    Ferny Grove
    my cold start injector plug (JDM LOOM) is black
  4. #24
    parrot
    The cold start injector plug is black, but the cold start injector plug is not the same as the cold start injector time switch sensor plug (which is brown as per the photo above)!
    Cold start injector is situated in the main body of the plenum.
    The cold start injector time switch sensor (i.e. the thing that signals to the ECU how hot the engine is and thus how long the cold start injector stays on for is located on that sensor block on the back of the head.
  1. WTB ADM AE86 ENGINE BAY WIRING LOOM+ 20v .5mm TRD HG
    By FAST EDDIE in forum Cars or Parts Wanted
    Last Post: 16th June 2011, 01:55 AM
  2. Neatening up the engine bay Wiring
    By rgeorgiou in forum KE70 / AE71 Owners Forums
    Last Post: 12th May 2009, 08:49 PM
  3. WTB JDM engine bay loom + rear coupe parts
    By omygtr in forum Cars or Parts Wanted
    Last Post: 11th February 2009, 12:44 PM
  4. fuses in 86 engine bay
    By mini bus in forum Technical - Questions
    Last Post: 19th January 2009, 11:42 PM
  5. Swaping ADM Wiring Loom with JDM Loom
    By joshcris in forum Technical - Questions
    Last Post: 20th September 2007, 03:18 PM
