Results 1 to 7 of 7
Thread: JDM alternator harness, use AE82/92?
    Ferny Grove
    Thumbs down
    just realised i don't have a Alternator harness for my JDM 16v. curious as to whether AE82's and AE92's use the same circle 3 pin plug on the back of the alternator, as it would be easier to find one of these than a JDM harness. even the plug for the alternator would help and i can just make my own harness.
    subsequently if anyone has a spare 4AGE alternator harness drop us a pm.
    had a look at a spare 4AC alternator i have and it uses a 3 pin plug on the back of a different shape. uses I, E and N pins. i assume the 4AGE alternator uses the same pin identification however it is not marked on the alternator body itself and don't want to assume that the pis are the same on either alternator.
    if this was the case i could presumably just modify the harness length to suit and change the fuse/circuit breaker to suit the higher amperage (if need be)?
    keen to get it all sorted by next week so i can start the swap.
    Ok
    Seamus
    Milton
    hey mate,
    me and electronics don't mix in the slightest, but if it's any help, cressida alternators use that same circle 3-pin plug that a JDM 4AGE uses
    ^ Clicky clicky!
    Ferny Grove
    yeah i'm not the biggest fan of wiring (traumatic 20v wiring experience)
    thanks for that, will keep that in mind
    Ferny Grove
    SORTED, will post results in later tech article i've promised.
    still feel free to answer though to help others.
    parrot
    I have a spare JDM charge/headlight loom but would have to have my arm well twisted to part with it. You can take it that unless you are really keen, don't bother. I tend to hoard everything!
    Ferny Grove
    found out how to do it and it seems to be quite simple, using a modded 4ac harness
    you need the JDM body loom to run the JDM charge harness etc. thanks for the offer though!! hoard away!!!
    parrot
    I love getting naked in the shed and rolling around on top of my JDM bits.
  1. Reco 4age alternator AE86 or AE82 Sydney
    By blue86 in forum Car Parts For Sale
    Last Post: 10th August 2010, 10:30 PM
  2. ae82/92 air con compressor on ae86 4age
    By barbel in forum Technical - Questions
    Last Post: 23rd January 2009, 10:55 PM
  3. JDM Wiring harness/loom......
    By NIZLAH in forum Technical - Questions
    Last Post: 5th January 2009, 06:33 PM
  4. WTB: 4age conversion parts OR ae82/92 car
    By marlon in forum Cars or Parts Wanted
    Last Post: 31st December 2008, 10:45 AM
  5. AE82/92 4AGE Smallport , Ignitor & Fuse/Relay Box for loom
    By csr in forum Cars or Parts Wanted
    Last Post: 19th September 2008, 10:09 PM
