Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 40
Thread: 4agze turbo?
    NT
    GENERAL AREA
    its just an idea at the moment but i would like to turbo charge my 4agze with a T28BB turbo, and yeah im pretty stupid when it comes to this sorta stuff so i will need sum help.
    -what do i need (manifolds etc)
    -cheap?
    -easy?
    and a 4age manifold how much modification does it take to make it fit a 4agze?
    just an idea at the time but any help would be good
    and can any one suggest a workshop to do it? or any one that wouldn't mind helpin me out?
    cheers guys see ya's on saturday
    Stefan
    Parkinson
    maby just look into nevo pulley system and get more boost???
    how much power do you want to gain?
    and what is your budget like?
    NT
    GENERAL AREA
    i wouldn't mind bout 160kw at the wheels
    the budget aint to flash at the moment thats y it was just an idea
    and where and how much r those pulley kits?
    Ryan
    chances are you have a stock 4agze like me.. and they are fun.. but yeah more power is also better for the cool factor.
    I agree with getting a NEVO kit first..
    because going from 90RWKW to 160 is going to be like going from driving a desel gemmy to a 180.. there its allot of power and unless you progress upto it and can drive it well.. you'll just be wasting your money...
    NT
    GENERAL AREA
    [/quote]
    [/quote]
    that is a very good point as i went from a celica to a 180sx and i nearly crashed that str8 away.
    so where do i get this NEVO kit from?
    Stefan
    Parkinson
    google search nevo pully kit there about $500 cheap power upgrade
    also get a hi flow fuel pump or you will kill your engine at top end
    id sugest bosch 044 external pump!
    NT
    GENERAL AREA
    already got an upgraded fuel pump plus 2L surge tank
    South Australia
    Aberfoyle Park
    Austrailia
    The setup is ins an AE86 I presume??
    Well, you could do many things to get that power figure, but I dont think that you will get 160kw at the wheels from a standard blower setup.
    This is what I did to my 4AGTE setup:
    - Custom Manifold
    - Custom Pipework
    - T25G Turbo (from 300zx)
    - Microtech MTX8
    - FMIC
    - Exhaust
    - Ported 86kw Inlet Manifold
    - 86kw Bigport Head
    This setup with a 4AGZE bottom end made 120kw or so on 9psi. Now bear in mind the turbo was maybe a bit too small for my application, and was second hand and 180,000kms old. A bigger turbo would cure this problem, especially if it was of a ball bearing variety. It all depends on how much money you have to spend too. But I could have had a 160kw at the wheels power figure if I had changed the turbo for a larger...say..Garrett T28BB Turbo or equivalent.
    Also, there are so many different ways that you could do it, but this is just what I did on my car.
    Hope this helps
    NT
    GENERAL AREA
    i got told sum where along the line that the pulley kit would raise the boost from 5 psi to 11-14psi how much power would i expect to see?
    i dont even no what its puttin out now or what sorta tune its got and all that but if i end up gettin the pulley kit would i have to get it tuned properly on a dyno?
    Joel
    Blackwood
    I'm building a 4AGTE at the mo.
    I'm using a Subaru TD04L turbs on a custom manifold.
    450x300x76mm core cooler, Microtech Gigi 2 Pro (old school) ECU.
    I'm using a GZE bottom end with a bigport GE head with a RWD manifold and TVIS plate removed.
    AE86 4AGE "Slowly but surely"
  1. 4agze to turbo Q's
    By Wyma in forum Technical - Questions
    Last Post: 24th January 2011, 09:14 PM
  2. WTB microtec for 4AGZE turbo
    By wattsys86 in forum Cars or Parts Wanted
    Last Post: 21st June 2009, 05:39 PM
  3. 4agze Turbo
    By Mr Fujiwara in forum Car Parts For Sale
    Last Post: 14th January 2008, 06:16 PM
  4. 4agze 20valve turbo
    By DriftPlease in forum General Topics (No Technical Questions)
    Last Post: 15th January 2007, 08:23 AM
