Results 1 to 6 of 6
Thread: Adjustable Camgears
    Jan 2010
    Hey,
    Anyone here have aftermarket adjustable camgears?
    I want to know how much adjustment in terms of degrees is available. I ask because I am making a set of adjustables based on the original and was not sure how to set the range for them.
    What is the standard range and how much would be needed on a 4AGE?
    thanks, Blake
    Sep 2009
    mine ajustable from '0' to -1 to +1 tooth, and correct me if im wrong (probably) 1 tooth is 10 degrees?
    Dave
    divide 360 by number of teeth = how many degrees per tooth
    - Blaise Pascal
    Jan 2010
    Sorry, Im not talking about dodgy standard camgears, think more HKS or TODA and how much adjustment in degree's they have.
    Mine will be adjustable using the plate type.
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    mine go -12/+12
    May 2010
    Fletcher
    Wollongong
    most go +- 12 degrees of Cam Angle - which is 24 degrees of Crank angle. That is a lot of base cam timing adjustment. It sounds like you are making a set - for your info the Fidanza ones are A$160 each from . Plus they are lighter than the standard gears.
  1. WTB adjustable equal 4link, adjustable panard rod,
    By _wanna-be_ in forum Cars or Parts Wanted
    Last Post: 8th April 2012, 11:55 PM
  2. WTB AE86 rcas adjustable 4 links + adjustable panhard
    By jakel in forum Cars or Parts Wanted
    Last Post: 27th February 2012, 02:00 AM
  3. 16v 4age, Quads, trd extractors, adj camgears, 20v ecu, thermos
    By sdrawkcab in forum Car Parts For Sale
    Last Post: 8th February 2012, 06:30 PM
  4. 4age adj camgears, rwd 4-2-1 extractors, light fly.
    By markiitourerv in forum Cars or Parts Wanted
    Last Post: 22nd April 2009, 01:03 AM
  5. adjustable 4 link
    By pen15 in forum Cars or Parts Wanted
    Last Post: 27th January 2009, 07:25 AM
