Results 11 to 20 of 26
Thread: auto
    Jul 2009
    if that fails try a A40D i think there called... out of an RA60 with 22re.. i had one with some of the finns flattened off (higher stall) that was behind a cammed up 18RG.. very torquey motors.. and had the stall at about 2900... not much but the converter was only touched a little bit... the guy had the 18RG in a KE55 or something like that, and told be it used to almost lift the front left wheel.. he said the suspension was at full extension when it left off the converter!
    what are you expecting to run??? you should even consider a 3pd auto from somthing like an RA40 celica.. they came with a 2.0 liter engine.. and actually had a tow rating so they might handle more torque than the 4a 3pds auto.. but for all i know they could be the same box!!!
    Dec 2006
    the box i got they also used behind some 6 cylinder cars i was told, going to see a mate that works at a toyota wreckers to see if i can sort something out if i cant ill get a flywheel made. I hope to run mid 12s all depends on how the converter works out might have to play around with it a bit, my workshop said when all is sorted should run low to flat 12s, hopefully i can lift the the left front wheel
    Jul 2009
    are you in brissy?? a mate of mine who runs a workshop whould be able to sort out a flex plate for ya
    From what I hear, the auto in Australian AE71s is a Trimatic unit. So that may open up possibilities for upgrading the internals with parts from old Holdens/Fords.
    Elite rthy's Avatar
    Leo
    Tulla
    if that is true then you could do just about anything couldnt you? I guess that begs the question; anyone ever seen a ae71 in japan with an auto?
    Dec 2006
    na mate im in melbourne ill be going soon to the wreckers i can use the flex plate off the 4ac just got to find the flywheel and im in business
    [attachment=10358:attachment]
    EDIT - I am a fool
    Dec 2006
    from what i can see the flex plate hasnt got the bolts for the fly wheel going through it so i should be able to use it
    Yeah, I stuffed up. And forgot what a flexplate was. I think it should be fine.
    Dec 2006
    thats cool its good to get all the info. the only problem i have now is the dick who put on the fly wheel rounded a couple and now i cant get them off. any suggestions?
  1. WTB MA70 auto gear or MA70 auto for wrecking
    By JDMBenji in forum Cars or Parts Wanted
    Last Post: 2nd August 2011, 10:39 PM
  2. slipping auto
    Last Post: 1st February 2010, 10:50 PM
  3. Looking for an auto App
    By shift_rook in forum Melbourne & Vic Events and Discussion
    Last Post: 15th March 2009, 10:12 PM
  4. any auto painters out there
    By 350hp4agte in forum Technical - Questions
    Last Post: 8th March 2009, 09:21 PM
