Results 1 to 6 of 6
Thread: rear leaf upgrade
    Adan
    Oxley Park
    Hi
    Im currently on holidays from work, and have been looking at spending the next bit of cash on the wagon. The front suspension seems to be pretty sorted seeing it is quite easy to get parts and information off here.
    Im a bit stumped when it comes to the rear suspension because i havent been able to find much information about anyone with a leaf spring setup.
    Id be looking to improve the handling a bit as well as lower it considerably (its 4wd stylez right now). I was thinking of bolting the stock ae71 sway bar mounts to the chassis and just putting a standard sway bar on from a sedan, though id have the problem of no mounts on the diff. Also the rear seems pretty stiff already, so with a bit of lowering and new shocks id be pretty happy, but i have no idea how they lower leaf springs, and im not sure i want to use lowering blocks.
    If anyone has any suggestions or expeience hit me up
    adan
    Veteran slide86's Avatar
    Huw
    Hills
    well you can either remove the springs and send them somewhere to get them reset to alter your height, or you can use lowering blocks.
    i have used the blocks before and havent had any dramas......
    Rob
    Moorabbin
    i will get getting re set leaves on my panel van, will let you know how they go
    im just going up in spring rate slightly and about 1 inch lower
    Adan
    Oxley Park
    ok cool.
    how much are you looking at to get them reset?
    at work we deal with a place that does leaf springs, but i havent seen their prices for resetting the springs.
    i think better shocks will fix alot of it so i mainly want to lower it for looks.
    Adan
    Oxley Park
    does anyone know how big the locating pins are on my leaves?
    i havent taken the diff off to have a look, and i need to know what size to get if i get some lowering blocks.
    also another question, does anyone know if the same shocks from ae86's and other corollas will fit?
    Jonathan
    The locating hole will be about 12 to 14mm. Yes AE86 shocks will fit. Also shocks from a XT130 or Commodore wagon will fit.
  1. Replies: 39
    Last Post: 13th June 2014, 07:13 PM
  2. KE70 Wagon Rear leaf spring bushes and 4a cam covers!
    By pt_y2k in forum Ebay Items - My Stuff
    Last Post: 12th November 2012, 01:24 AM
  3. Rear Brake Upgrade: JDM T-series
    By takai in forum Technical - Questions
    Last Post: 12th August 2011, 11:19 PM
  4. Xe7X rear leaf springs
    By starni_boy in forum Cars or Parts Wanted
    Last Post: 19th April 2011, 07:35 PM
  5. te72 rear brake upgrade
    By tea18 in forum Technical - Questions
    Last Post: 10th February 2009, 08:42 PM
