Results 1 to 7 of 7
Thread: T Series Diffs
    What the go with T series diffs in coronas. Are they any good for the 70s, 71s and 86s?
    What mods need to be done? I'm sure there is.
    Dec 2006
    thats something i would like to know as i need a good diff in me ke70 wagon
    Eddie
    Coronas dont come with T-series diffs.... they have crappy Borg Warners or the IRS versions have F-series diffs.
    Eddie.
    Jonathan
    Um, thanks Eddie. Some Coronas come with T series diffs. In fact most RWD Coronas with live axle outside Australia would have T series diffs. I think only the XT130 and ST141 had BorgWarner diffs. I know the RT132 (liftback) does have a T series, and I got one. It can be used in a AE86. It is probably similar or the same as a RA40 rear end, in that the mounts almost line up. You would need a adjustable panhard rod or something. The whole housing is wider, but only by about 10 or 15mm.
    From memory, the older Coronas also like RT104 had a Toyota diff.
    One issue is that the Corona diffs often have a ratio like 3.9:1, but the Celica diffs have a 4.1:1 ratio which is better. It all swaps over.
    yeah, i also have a T series from a corona lift back, also took front struts and LCA's speaking of which, does anybody know if they are the same length as a XT130 LCA? ad assume they are but might be wrong.
    the diff is 1420mm from drum to drum from memory, came from a manual car but im unshure of ratio as i havnt had a good look at it yet.
    Eddie
    Yep yep, sorry dudes... im so used to only looking for ST141/RT142s Coronas for the brakes that i forgot about the others! RT104/132s are the ones with the T-series. RT104s come with a 4.1 ratio dont they?
    Eddie.
    Veteran slydar's Avatar
    Dimitri
    one of the corona's does, thats what josh got his last 4.1 out of he was telling me.
    78's
  1. F series, G series, T series 4link diffs ready to bolt in also W58s
    By sumfancyname in forum Car Parts For Sale
    Last Post: 11th August 2011, 09:39 PM
  2. t series diffs
    By ae71dwrifda in forum Technical - Questions
    Last Post: 12th May 2009, 08:52 PM
  3. whats the difference between S series diffs and T series
    By AE86dori in forum Technical - Questions
    Last Post: 27th June 2008, 06:44 PM
  4. LOCKING S SERIES DIFFS
    By superbmobile in forum Technical - Questions
    Last Post: 2nd July 2007, 09:06 AM
  5. where the hell have all the s-series diffs gone?
    By cri_ag in forum General Topics (No Technical Questions)
    Last Post: 20th February 2007, 10:20 PM
