Results 1 to 6 of 6
Thread: 4AFE with 7A bottom end?
    Jul 2009
    long story short, 7A-FE bottom end (fresh and cheap) replaceing a 230km worn out 4afe bottom end, not for the purpose of racing or a quick car etc etc, just a little bit more mid range for daily driving (my mum and dad),
    but the head has been done recently, so my idea.. pull motor out, fit new h/g to 4afe head ontop of 7AFE bottem end, leave ecu injectors etc etc everything stock as a rock 4afe stuff.. minor mod to the exhaust (as the 7a block a little taller).. will the injectors/ecu be ok with running an extra 50cc each cylinder? sureley it won't run lean or anything right?? there is enough sensors on it to register a slight difference and adjust slightly??
    your thoughts..
    thanks
    Will
    i wouldn't do it, at WOT the engine would assume a set VE, and put in fuel that is appropriate for that at whatever RPM
    if it was an AFM engine it wouldn;t be such a bit deal, and at light loads it might not matter anyway.
    what you could do is put in a set amount more fuel over the whole range, but i think it would be more hassle than it is worth.
    if you want to try it, put it on a dyno to make sure you arent going to melt those crappy pistons
    Elite rthy's Avatar
    Leo
    Tulla
    isnt 4afe's/7afes afm?
    I reckon it'd work. From the factory it'd probably run on the rich side anyway, so a little leaner wouldn't hurt. Or you could just up the rail pressure (adjustable or find a suitable regulator that is set slightly higher) to compensate.
    Though I really doubt it'd be worth the hassle. Though it depends how much your folks want their daily to be a project car and off the road. I think there'd be little problems fitting it all together and getting it running nicely.
    Jul 2009
    smack the end of the fuel reg in a wee bit with a pin punch ups it a few psi
    this 4afe is map..
    Jul 2009
    once running i can throw a wide band o2 sensor in the back and see what it displays.. as long as it's no higher than 13.5 i reackon she will be fine!
  1. 4agze bottom end, 7afe bottom end other stuff
    By FORDISGAY in forum Car Parts For Sale
    Last Post: 20th November 2012, 04:34 PM
  2. 7a-fe bottom-end wanted
    By ae8616v in forum Cars or Parts Wanted
    Last Post: 9th June 2011, 12:27 PM
  3. WTB: Complete 7A bottom end - VIC
    By boh086 in forum Cars or Parts Wanted
    Last Post: 14th June 2010, 01:52 PM
  4. WTD: 7a bottom end SYDNEY
    By levinracer in forum Cars or Parts Wanted
    Last Post: 25th April 2009, 05:43 PM
  5. 7a bottom end and crank
    By grantobius in forum Cars or Parts Wanted
    Last Post: 7th April 2009, 06:39 PM
