Results 1 to 10 of 18
Thread: waterpump/ radiator
    Aug 2005
    well just busted the rear part of my waterpump where the thermostat plugs in and i was wonderin what replacement can i use for a rwd one if i cant get a hold of one.
    also a replacement radiator too. what ones can i bolt straight in if i cant get a sprinter one??
    thanx
    parrot
    Nothing is a straight bolt in.
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    The 4AC uses the same backing and front part of the water pump. Should only be like $30 from repco or sprints or somehwere like that.
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
    Jonathan
    The front half of the waterpump is about $50 from Burson. The whole waterpump (front and back) is about $100 from Toyota.
    Jonathan
    The water pump (both halves) on a RWD 4A-C is the same as that on a RWD 4A-GEU. So all AE86 water pumps are the same, 4A-C and 4A-GEU.
    FWD waterpumps are a bit different, and do not have a thermostate housing in them.
    Jonathan
    Repco will probably only give you the front half. You need to go to Toyota for the whole pump. (And be armed with details from a ID plate).
    Veteran driftism's Avatar
    Andrew
    Watsoia
    the rwd 4ac ones will not fit on a ze... there is a supercharger in the way of where the lower hose is supposed to come out. I also believe that the rwd series 4ag's have a different offset waterpump pulley to the fwd engines, but this i am not sure about.
    not so jdm 4age pumps have a longer shaft for the clutch fan and the pulleys wont line up!
    im using 4ac housing ae82 4age pump
    Jonathan
    No Blinky you can't just do that. To make that work you have to grind the fins inside the waterpump.
    Remember 4A-C came both RWD and FWD, so need to specify.
    Brendo
    ^^ thats what i thought
    THIS IS <<R2>> Blinky
    Fuk im confused lol
    Basically i want the neatest set up possible to convert my engine cooling to rwd
    So if i use the rear half of a rwd 4ac waterpump i have to grind down the fins?
    Then i can use a 4age FWD front half to get the right pulley off set?
    If im wrong this time can some one direct me in the right direction for what im after lol
  1. 4ac waterpump same as 4age rwd waterpump?
    By simonster in forum Technical - Questions
    Last Post: 25th October 2007, 10:11 PM
