Yes the rods have a 45mm big end and the bearing is the difference to a 42 big end crank. Just if I say 45 big end rods stupid people don't know the difference.
Don't you mean 20mm pin and 45mm big end. They have a 42mm crank but the big end bore is 45mm. I would check to see if you have ordered the correct ones. 40mm Crank is about 43mm big end bigend bore. I have just ordered a set of Pauter rods and I have ordered 20mm pin with 45mm big end to fit a 42mm crank.
No worries I was just checking. I was just making sure as it is easy to make a mistake and it can be confusing to some.
Good luck with the sale.
nice free bump
I can machine the big ends if they're wrong.
The parts guy left work!! I don't know if I can get parts cheap any more, whens this getting all wrapped up?
listen here puff yr wagon and sexy 16 [b]both of u only have 16v and 8v real men have 20v lol
see u guys on fri nite
Have checked with Argo rods are due end of Jan - Just need to prostitute myself to have the dosh for the unsold units or else will just use credit card. Will post a pic of the forums biggest rod gathering shortly. Will have to leave the 4K push rod group buy for the moment
think puff should pull his head outta his arse and stop talking of things he knows nothing about.
If anyone organisies a group buy for 7A rods you can count me in.
i can get them for $1250 through my supplier, but hes just a middle man so dont think he will do this any cheaper.
Im assuming these 4age rods are coming directly from argo hence the discount.
you tell the puff bloke dan you tell them
up the mighty powa of the 7age
Settle Dan - if you can't tell - Puff is only joking. The rods are direct from Argo. 4age ones are that price also (normally) - my advertised price is because I have purchased 10 sets - thus the group buy discount. You will need a $3,000 deposit before they will commence production with the rest payable when the comptete the order.
Paul - I have lost my 10mm ring spanner. John thinks he might have left it in your sump. I need it back as it is part of a set.
Cheers Peter
