Results 1 to 10 of 12
Thread: w58/ae86 speedo cable
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    hey all, i am doing a 20v conversion ATM and i will be running a w58 supra 5 speed behind it, just wanting to kow if there is any problems with the speedo cable screwing onto the box... does it go straight in? or do you have to get something made up 4 it to work?.... any help would be appreciated...cheers guys
    MY JZX83 (clicky)
    Jonathan
    The cable screws in, no problem.
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    Gearing may be wrong though, mine reads 20kmh faster
    w57 with 4.1
    Brendan
    NORTHSIDE YO
    yeah i was thinking it might do something like that being a 6cyl box and i will also have 4.1:1 aswell so do you think my best bet is to get an A/M speedo that u can set to 4/6/8 cyl? or is there another way to get around this?.... cheers 4 the help so far guys
    MY JZX83 (clicky)
    Jonathan
    No, it is the Tacho you are thinking of, that may have a 4/6/8 cyl button. The speedo is a mechanical device. I think the best way to fix the ratio is to get the little plastic gears from the back of the gearbox and swap them with a set from a gearbox that had the same diff ratio as you will be using. That is assuming most speedos also have similar ratios, which I think they do. You maybe looking for speedo gears from a HiLux gearbox that had a 4.1:1 diff. The hiLux will say W56 G292 on the firewall.
    There maybe numbers on the back of your speedo cluster. To work it out properly you will need a calculator, think very hard, know the number of teeth on all speedo gears, diff ratio and find the circumference of your tyres.
    Brendan
    NORTHSIDE YO
    yes i know the tachos can do that, i thought that speedos would do the same thing....... what if i got the speedo cable off a old supra.... that came with w58 would that work????
    MY JZX83 (clicky)
    As said above the speedo cable plugs in and works fine.
    Changing the box wont change your speedo reading. Only changing your diff ratio and tyre size will do that. If your speedo is out you can either live with it, have the speedo recalibrated, or change the gears in the speedo drive in the box so they match up properly.
    I use option A.
    Brendan
    NORTHSIDE YO
    i think ill just live with it, i will have a w58 into a 4.1:1 diff and 205/50/15's on it... will it be out by much?
    MY JZX83 (clicky)
    Steve
    Padstow
    That similar to mine, and mines reads faster 20%
    Brendan
    NORTHSIDE YO
    ok kool thanx 4 the help guys
    MY JZX83 (clicky)
  1. Speedo Cable for AE86
    By jonbatz01 in forum Cars or Parts Wanted
    Last Post: 23rd September 2012, 09:28 PM
  2. ae86 speedo cable
    By drft86 in forum Cars or Parts Wanted
    Last Post: 21st October 2010, 12:06 PM
  3. AE86 Speedo cable
    By Judge Fudge in forum Cars or Parts Wanted
    Last Post: 27th September 2008, 05:38 PM
  4. AE86 Speedo Cable
    By Snowman in forum Cars or Parts Wanted
    Last Post: 22nd August 2008, 04:19 PM
  5. ae86 speedo cable
    By irl86 in forum Cars or Parts Wanted
    Last Post: 10th January 2008, 03:22 PM
