Results 1 to 3 of 3
Thread: KE70 Water Pump
    Hey guys, the other day while cruising about, my heater hose burst coz the outlet on the water pump was corroded and sharp, so i swapped my water pumps with one fromanother engine i had, and i made my own gasket and cleaned the surfaces and all that and put it back on the car and filled with water.. it leaked, at first i thought it was the gasket so i got some silicone and made myself a gasket with that... it still leaked, so i had a look at where it was leaking from and there was a random hole on the pump, which it was trickling out of, but this hole was on all my water pumps,
    my question is, what are these holes for, because i sealed over the bottom one only to find that it now leakes out the top as well,
    WTF??
    i need to know if it matters if these holes are sealed or not, like what is the normal occurence for this water pump??
    Dec 2006
    they are weep holes, basically when your water pump is fucked it will leak here, no they r not suposed to be blocked up, all cars waterpumps have them.
    cheers, i knew they were meant to be ther and all that, but i didnt exactly know what they were for but then i kind of figured that it shouldnt be leaking from there in the first place so i quickly realised that it was fubarred, plus some of the fellas from SD.com told me that as well
  1. Replies: 0
    Last Post: 7th October 2011, 07:37 AM
  2. Oil pump, water pump, thermostat . . .
    By AE86 Spoontah in forum Car Parts For Sale
    Last Post: 13th July 2011, 10:13 PM
  3. Need water pump for ke70 now!!!!
    By billett86 in forum Cars or Parts Wanted
    Last Post: 18th February 2011, 04:53 PM
  4. water pump/ water pump pulley
    By kronix in forum Technical - Questions
    Last Post: 19th February 2010, 07:45 PM
  5. WTD, 4age water outlet, the one above the water pump
    By gaz20v in forum Cars or Parts Wanted
    Last Post: 11th December 2009, 11:56 PM
