YES CURRENTLY RUNNING AE92 SUPERCHARGER COIL PACK WITH MICROTECH ECU...PULLING 118.8 KW AT THE WHEEL... JUST LOOKING FOR MORE POWER AROUND 150KW..
PLANING TO GO TURBO FOR MY 86 ....WHAT DO I NEED...
CURRENTLY SETUP :
ENGINE: AE 92 165 ps SUPERCHARGER COIL PACK
ECU: MICROTEC
PART I GOT:
TURBO t-25
Turbo Manifold
SO WHAT SHOULD I GET FOR THIS?
INTAKE MANIFOLD....100kw OR 88 kw?
ALTERNATOR?
COIL PACK ?
INTERCOOLER? WHAT SIZE?
Um, you need to take the manifolds off. Then put the intake manifold on, and bolt the turbo on.
Then you need to connect a hose from the turbo to the intake. Done.
Then go to AutoBarn to get all the fully sick stuff. Blow off valve etc. Optional boost controler.
Oh, I just remembered you may also want oil pressure to the turbo, oil drain to the sump. Water lines to the turbo. A dump pipe. A intercooler, whatever size you want to fit.
..bigger injectors? Aftermarket ECU.
you'll need to modify your alternator bracket & waterpump or buy a rwd water pump assembly and alternator bracket (intake side, adjustable)
get a rwd bigport intake manifold
get a tvis plate and remove the butterflies
thats about it
n u you will prob need a t28 or bigger.to ruun 14psi or more to get the 150kw at the wheels.need help
holla.just finish a 4agte setup.
