Results 1 to 5 of 5
Thread: > Fueling Problem
    check if ur fuel pump is pumping fuel get a test light and check while someone is cranking the car.... if theres no power goin to the fuel pump follow the cable back to the ecu and check if there is a good connection in the plug
    i had the same problem
    so is this after u done a engine swap or just a injectors swap?
    i had similar problem.
    i had to change engine so i use the stock injector that came with the engine
    but it didn't start up.
    i found out it was the injectors were of wrong impedence
    i swapped the injectors back to high impedence which i was suppose to use because of my microtech then it
    starts first go.
  1. Blacktop 20v excessive fueling - Video Attached
    By Matt in forum Technical - Questions
    Last Post: 29th November 2011, 05:12 PM
  2. need help s/t 20v over fueling poor ventilation setup
    By ae8620v in forum Technical - Questions
    Last Post: 16th June 2011, 01:14 PM
  3. Oil change -> Oil leak problem
    By Driftspec in forum Technical - Questions
    Last Post: 26th November 2009, 04:12 PM
  4. t50 4A bell -> t50 2T gbox seal problem
    By PULSE in forum Technical - Questions
    Last Post: 15th June 2008, 12:29 PM
