Results 1 to 10 of 12
Thread: rwd water setup on fwd?
    JP
    Eastside
    HEy guys
    got my new motor.. heres the catch its fwd.. and i want to use all the legitament rwd waterpiping.. and altnator bracket.. im just wondering will the harmonic balancer pulley still line up with the rwd altnator and waterpump?.. or am i better of using the fwd front half and use the rwd back part of the waterpump?..
    jace
    Elite rthy's Avatar
    Leo
    Tulla
    if u use the rwd 4age water pully then its ok, if u use the fwd pully it wont line up
    Shane
    Giday, have you actually seen this work? Reason being, the rwd crank pulley has a different offset to the fwd crank pulley
    e.g. rwd on left, fwd (gze) on right
    Even if you were to use the rwd waterpump pulley and rwd water pump the belt will not perfectly line up with the fwd crank pulley.
    Ive read of lots doing this. So im guessing the 1-2mm difference in offset is not enough to upset the belt?
    I'd like to hear from someone who has the above setup (rwd pump and pulley) and is still using the fwd crank pulley.
    Veteran driftism's Avatar
    Andrew
    Watsoia
    I have a fwd AE90 crank pulley on my JDM RWD motor... works fine.
    Jonathan
    I think the main pulley closest to the motor lines up ok. The outer pulley is only used for A/C or power steer. I don't use that so I have machined mine off to make it lighter.
    Nick
    i have the same as you, a 4age configured for rwd, running a fwd water pump and alternator from an ae82/92 corolla.
    i know for a fact that a rwd 4AC water pump is longer and the pulley sits further forward. this obviously uses a different kind of pulley and fan belt as well, not the 5PK 4AGE belt.
    but even if you swap the pulley on the 4ac water pump it doesnt line up.
    it is certainly easier to use the fwd waterpump, alternator brackets and an external thermostat. because the rwd stuff is hard to find and people charge STUPID amounts for it. there is a really good guide on this site i remember looking at.
    hope that makes sense
    JP
    Eastside
    yeah i just wanted to neaten it up a bit im using that same thing external thermostat housing from a 4ac fwd car. cheers for the response guys i've gone to the external thermostat housing..
    jace
    Elite rthy's Avatar
    Leo
    Tulla
    yea i have that now and have had no problems
    if u check the old toymods or rolla club they have more details
    Brendo
    instead of starting a thread i thought i would add my question to this one,
    what is the deal with the bigport water outlet on the back of the head, the one with 2 sensors in it, obviously the pipe runs to side of head where the hose conects to it but what is the deal with that little pipe coming off the main pipe at right angles about 6-7mm wide?
    whats it for? and how do u block it up
    Brendan
    Jonathan
    Are you talking about the heater hose outlet?
    Or are you talking about a little water hose? Small water hoses would originaly go to the throttle body to warm it up. People often discard this function.
    Most EFI Toyotas have 3 water temp sensors. One little old style one for the temp gauge. One newer style one for the computer. And one often near the thermostate to turn the fan on (but RWD Toyotas don't have electric fan).
  1. jdm 4age water setup into RWD 4agze?
    By slipn in forum Technical - Questions
    Last Post: 12th October 2012, 06:28 AM
  2. RWD water setup
    By wanted_ae86 in forum Technical - Questions
    Last Post: 11th May 2012, 09:26 AM
  3. WTB: Working FWD 16v water setup and alternator
    By willa in forum Cars or Parts Wanted
    Last Post: 7th September 2011, 06:02 PM
  4. RWD 4age/4ac water pump setup
    By paul123 in forum Cars or Parts Wanted
    Last Post: 23rd August 2009, 07:27 PM
  5. water pump pulley, FWD-RWD, how do i tell?
    By land yacht in forum Technical - Questions
    Last Post: 11th June 2009, 08:02 PM
