Hi all, I am getting a 4AGTE to put into my AE71 and suspect the standard cooling system will be insufficient. Has any one done a similar install with helpful advise? I have seen it done with only getting the stock radiator flushed by a radiator repairer, but don't know if this would cure overheating? What radiators are you running and does the temperature rise above what it should?
Also am not sure whether I should run quad induction or a JDM rwd intake manifold. I am thinking JDM rwd because of cost and easier instalation. Would there be much power to gain by going for quads? I expect the power output to be about 170rwkw.
All help appreciated as I have never dealt with either of these issues and value others experience, thanks, Asher.
