OKay I know this soundslike a bit of a noob question but i do have a vague idea just after the particulars!
So here is the deal a ae93 corolla runs a small port 4age mounted eastwest.
To run quads on this setup you need quads(obviously), the adaptor plate (T3 sell one).
My questions are
Can u use the existing accelerator cable?
Do you use the 16V ecu or a 20V ecu? I have heard that it will run on the 16V but is a bit rich?
Aftermarket ecus? Has anyone used a megasquirt with this setup? Am i right in thinking that without an aftermarket ecu the quads will not really increase power?
How well will the quads fit in the bay? I'm pretty sure that they would fit even with the adaptor plate but what about air ducting? THey would be facing backwards so some ducting would be needed.
Now on another note does anyone know if you can fit a supercharger onto the small port in a ae93 engine bay?
Just doing a bit of research for a new project maybe![]()
Anyone with some solid knowledge or who can point me in the direction of someoone who knows/ has experience with ae93s will be muchly appreciated
Cerby
