Results 1 to 10 of 15
Thread: 4age Cam Positions (tdc)
    Sep 2009
    I'm tying to debug my motor problems. Would some one be kind enough to take a picture of the cams at TDC cylinder one? I just need to know if got it I'm the ballpark as my cam gears are modified.
    Also what stroke is the egine about to do (intake, spark, compression, exhust) when at TDC cylinder 1?4age Cam Positions (tdc)
    Dec 2006
    theres a mark on each cam gear looks like a dot, they should line up with the marks on the rear cover at the top. soory no pics
    Sep 2009
    yes i know, but my cam gears are modified
    Dec 2006
    then u proberbly have to look at the cams the way they are opening the vavles
    Sep 2009
    yeah i know thats why i want a pic. And i dont know what kinda of stroke tdc is so know the cam postion is useless without that.
    Get number 4 cylinder valves/lobes rocking and the number 1 cylinder will be a TDC. That will give you a ballpark. If you want it exact you will need a degree wheel and a dial indicator.
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    It will be compression one number 1 cylinder at TDC.... So both lobes (exhaust and intake)will be on the flat side pushing on the valves
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
    Ferny Grove
    HOT TIP
    i know for certain the intake cam has a little tic tac shaped indent in it. when it faces straight up "visible through oil cap hole" thats no1 TDC. i can only assume the exhaust cam has the same....
    Jonathan
    The cam gears have a hole for the dowel on the cam. This is visible near the washer under the main bolt. This should be facing up on both cams when the crank is on 0.
    Dec 2006
    on my engine the inlet cam dowel is facing up and the exhaust is almost facing down when the crank is on 0
  1. 4age 16v cam covers or inlet side cam cover
    By klusio in forum Cars or Parts Wanted
    Last Post: 19th August 2010, 01:51 AM
  2. W58 Shifter positions
    By DR1FT in forum Technical - Questions
    Last Post: 16th June 2008, 10:23 PM
  3. Bov positions
    Last Post: 18th February 2008, 09:32 AM
