Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: 4age Cam Positions (tdc)
  1. #11
    Sep 2009
    ahhh dam, the timming was right.... thats would of been a nice soltuion to my engine trobles
  2. #12
    Jonathan
    If one dowel is up when the other is down, it just means you have 2 exhaust cams, or 2 inlet cams. Does not matter, as they are both the same apart from the dowel.
  3. #13
    Dec 2006
    i cant have two exhaust cams as only one has the gear that spins the dizzy, so if u had both the same how would the car run wouldn't it be hard to fit one of the cams?
  4. #14
    Sep 2009
    4a wagon is right. The cam gears have to holes were the knock pin can go, but my modded (ajusable) cams only have one which was causing problems
  5. #15
    Dec 2006
    i hope i was thanx jas.
  1. 4age 16v cam covers or inlet side cam cover
    By klusio in forum Cars or Parts Wanted
    Last Post: 19th August 2010, 01:51 AM
  2. W58 Shifter positions
    By DR1FT in forum Technical - Questions
    Last Post: 16th June 2008, 10:23 PM
  3. Bov positions
    Last Post: 18th February 2008, 09:32 AM
