Results 1 to 10 of 14
Thread: power specs
    hey just wanting some power specs on 4ac's ,4age's and whatever else comes in and can be bolted into an ae
    86. i am keen to know both stock power and potentual power ( with standard internals ) and also reliability.
    basically i'm trying to find out the cheapest most powerfull setups that are still reliable . also it will probly be
    used as a drift car most of the time so i want some thing that has good response and torque curve .. thank' s
    Veteran anastasios's Avatar
    Taz
    Earlwood
    search dude
    thats what i'm doing i thought someone on here might know . if any one has done conversions or mods that have worked out well i'd like to hear from u .. cheers
    Elite rthy's Avatar
    Leo
    Tulla
    the cheapests stock power and potentual power is a s13 CA18DET, but for lil more u can so SR
    justin
    Hills District
    CA18DET is an awesome motor and its not hard to get 180rwkw with just EMS injectors I/C and a bigger turbo.. motor box loom combo can be had for $1500 max ( if u look around its cheaper) stock they put out 130kw at the motor.. s13 SR20DET put out 150kw at the motor and internally can take 200-220rwkw day in day out for a few years without too much trouble b4 a rebuild... u can buy kits to mount the motor and box into the ae86 for around $350 ( fo rthe CA18DET) PM SLYDAR i think thats his name
    my stock silvertop 4age 20v with just ems quads and 4-1 extractors made 98rwkw at J.E.M.. it definately needs alot more go, next thing id be chasing is 180+rwkw to have sum propper fun hahaha
    cool cheers 4 ur help 2 more questions what would i need to put a 4age into a 86 that has a 4ac is it a staight up bolt in job ? do u know no how hard it is to wire up a ca in an 86 or how much it cost ? i have had a couple of ca's b4 . i put one in a s12 not too long ago and it was pretty crazy lol great fun to drive but the wiring up was a nightmare . cheers buddy
    justin
    Hills District
    Search up these forums for the 4AGE swap... just use 4age mounts and matching RWD box and it all bolts in... u might need to swap to an efi tank or install a surge tank and primer pump in the rear..
    to wire up the CA18det id recomend an aftermarket computer and to get that wired into the cars loom( saves $$$ later if u want more power eg $350 to wire up the stock ecu then $500 to do the aftermarket one thats $850 instead of just $500 plus computer cost). its not that hard and most places will do it for $500 tow in drive out..
    Jul 2009
    power specs for 4ac see below:
    Junk.. to low to read....
    Joel
    Blackwood
    ^^^boooo.
    4AC's are very capable motors.
    Its just that most drivers are not capable of driving them.
    AE86 4AGE "Slowly but surely"
    ^^^ But the most capable-est drivers' engine of choice is definitely the 3K.... with Toyoglide 2speed auto.
  1. Replies: 10
    Last Post: 22nd December 2012, 03:21 AM
  2. 4AGZE Injector power, how do i give it power?!?
    By s3phro in forum Technical - Questions
    Last Post: 24th May 2011, 11:28 PM
  3. Specs
    By benbertucci in forum Technical - Questions
    Last Post: 24th June 2009, 03:43 PM
  4. power specs
    By dori king in forum General Topics (No Technical Questions)
    Last Post: 25th January 2007, 07:20 AM
  5. new petrols, v power, v power racing. utd 98 + ethanol
    By yoshimitsu9 in forum General Topics (No Technical Questions)
    Last Post: 8th December 2006, 12:57 PM
