Results 1 to 10 of 10
Thread: 4AGE fuel problems
    Justin
    hey guys,
    my sprinter died on the way home from the coast this morning, it was a problem that got gradually worse over the course of the 1 hour drive, and i got 10 minutes from home and its completely dead now
    basically i can start the car, it will idle at about 200rpm, and if i apply any throttle at all it will stall, lots or a tiny bit.. and i had alot of trouble driving it just before it died, cause i was so close to home i was trying to limp it, if i let the revs drop below about 4000 it would just die and stall, but above that it seemed to go ok, but only on about half power..
    i think it is fuel related, fuel pump still works, it appears to be sparking fine, everything else works, just the throttle goes all mushy and it coughs and splutters, very similar to if i try to start my car and i have the fuel pump immobilised...
    any ideas of what wiring it could be? i have checked the immobiliser is working fine and is off, what can i check wiring/computer wise?
    thanks in advance for any advice
    btw it is a blue top 4age, factory computer.
    I started the ball rolling...
    Not member #1 anymore
    Jun 2009
    Michael
    Fuel pump. Had the same issue with mine a few weeks back. What sort of fuel setup you running? Surge tank etc..
    Justin
    i have a vl turbo fuel pump, no surge tank (just have to keep it above 1/4 full so it doesnt surge)
    i thought i may have got a bad batch of ultimate and i got a clogged fuel filter, cause i didnt run it low enough to suck up the crap from the bottom of the tank..
    and when i start it you can hear the pump kick in like normal, then go off when pressure is built up..
    Jun 2009
    Michael
    Do you run a lift pump or just the VL one. I also run the VL turbo pump but have a lift pump and surge tank. The Vl turbo ones are high pressure low volume pumps. You should really have a lift pump (low pressure, high volume) to supply your main one.
    Justin
    this set up has worked fine and been quick for the last 5 years... i just want to fix what has broken for the time being...
    Jun 2009
    Michael
    Id recommend a new fuel pump then. If its in a easy to reach location try giving it a 'love tap' while idling.
    do u have a relay for the pump
    stefan
    vic
    eastern suburbs
    check the fuse near the ecu that belongs to the relay that runs the fuel pump on ignition. beleive it or not justo it happened to me too when i was degreasing the engine bay at the car wash, somthing shorted and fucked the relay when it would run for a little while and then die
    justin
    Hills District
    where did u check the fuel pump for pressure?
    u pull the line off at the motor or just listen for the pump to turn on?
    also replace the fuel filter, never hurts..
    did u run out of fuel b4? say in the last few tanks?
    tis the fuel pump des, i had same problem long ago. fuel pump des..
  1. Fuel gauge problems AE86
    By BARWICK in forum Technical - Questions
    Last Post: 5th October 2011, 01:03 PM
  2. 4AGE 20V fuel problems
    By 70XIN in forum Technical - Questions
    Last Post: 27th April 2011, 01:28 PM
  3. heat and fuel gauge problems
    By Sprinter Freak in forum Technical - Questions
    Last Post: 18th April 2011, 06:24 PM
  4. SR 86 fuel problems
    By adam_loves_hachi_roku in forum Technical - Questions
    Last Post: 8th October 2009, 07:35 PM
