Results 1 to 10 of 18
Thread: 16V head on 20V ST block
    Oldschool Member
    Oct 2006
    I've tried some searches and did not find specifics on the head swap. The only thing I really want to know is if I could bolt the 16V head on to the 20V ST without having to change the pistons. If anybody has done this and can provide any information, it would be awesome.
    Alex
    sydney
    no
    4 valves vs 5
    Sprntrphle - Are you sure? I see where you're coming from, but have you actually tried it?
    From what I hear, 20V head on 16V ZE bottom end works without munching valves. This may be the same.
    Elite rthy's Avatar
    Leo
    Tulla
    it does work but it will no longer be a non interference engine. In other words a 16v and a 20v when they snap a belt dont touch valves, when you use a 20v block and a 16v head it will, but belts dont snap often and silver belts are cheap. Also use a 16v gasket
    why do you want to do it cheap? cheap compression raise?
    Oldschool Member
    Oct 2006
    I want to do it cheap for now, because current budget does not allow me to have a full 20V swap. My current 4ag smokes more than I would like it to even though it pulls really good and I can smoke out people who piss me off on the roads. I have to add a quart of oil every week. I figure if I can do it this way, I can put on the 20V head later when I gather the rest of money to do the full 20V.
    Oldschool Member
    Oct 2006
    For this swap I use the 20V timing belt?? I would probably figure it out when I do it, but knowing before hand would save me a lot to time. Anyone know what the correct 20V timing belt match is for a USDM car???
    Terry
    Ipswich
    the 16V head will bolt straight on. use the 16V head gasket and timing belt provided your 20V has the early type tensioner roller on the cam belt (the type with a spring for tensioning)
    Oldschool Member
    Oct 2006
    Looks like the head swap is going to happen this month. I failed my emissions test, the guy doing the pipe sniffer test says it failed because its burning oil.. I'll let you guys know how it goes...
    Brad
    im interested in doing the same build aswell.
    can you use the 100kw pistons in it aswell? im not 100% but i believe they are a higher compression ratio aswell?
    thanks brad
    Apr 2006
    a mate of mine has done this swap, and boasts about it. he says the torque is lots better. he done this conversion due to not having to get an engineers
  1. Replies: 0
    Last Post: 19th May 2011, 09:40 PM
  2. mach oil temp gauge plus st 20v bottom end with 16v head
    By dehney in forum Technical - Questions
    Last Post: 7th March 2011, 09:42 PM
  3. 16v head on 20v block
    Last Post: 30th October 2010, 06:27 PM
  4. Replies: 7
    Last Post: 2nd September 2010, 04:17 AM
