Results 1 to 10 of 12
Thread: brief guid to bog
    Jun 2005
    im goin to bog up the treated rust on the rear of my sprinter tomorra but i really have no idea what to do as yet
    im hoping u guys could give me just a brief step-by-step guide on how to mix it and apply it and so on so forth? - a few words from the wise
    thanks guys
    1 - Do proper prep. If not you will be doing this whole process again in a few months. File/sand/brush back to bare metal. Then use rust converter. Sounds like you may have done that already.
    2 - I then prime with a spray primer
    3 - Read instructions on bog tin. Mix bog and apply, Try and ensure all parts are above the final surface you want. If the bog sets too quickly, don't try and keep applying it, you'll always get holes in it. Stop, wait for it to harden, then mix a new batch and continue.
    4 - Take your time.
    Junior Member skiddz's Avatar
    also if there is nothing behind where you have cut out the rust, put somting behind there, its ideal to put metal in there, weld it then only put a minute about of bog only to even things out and make it look good, bog=evil
    Mar 2006
    I like to use fiberglass on big patches of rust as bog will most likely crack and fall out.
    kravit
    bowen hills
    Mate i would use tiny bit as bog as possible on dents, wouldnt fill up anything deeper then 2-3cms.
    Dont get into groove on eventualy sculpting out big areas of car out of bog cos it will crack.
    Jun 2005
    ill show ya where the rust is:
    [attachment=11971:attachment]
    it is all in that ridge inside the red ovals and as u can see its in a pretty awkward place on the car. its gonna be hard to spread bog in there and its also gonna be tricky to weld a peice of metal there coz theres is not much room
    (thanks HYPNTK for the pic)
    kravit
    bowen hills
    Well aslong as ur not filling up holes should be fine
    You can even get away with not doing it properly since bumper covers that. Aslong as rust is all gone and no holes should be fine.
    Jun 2005
    yeah thats the problem.................theres holes there and they let in exhaust fumes so thats why i need to cover them up otherwise i wouldnt bother with it
    Veteran anastasios's Avatar
    Taz
    Earlwood
    sand it all back to bare metal and get it all welded up properly will save u headaches in the long run and will be stronger
    Veteran driftism's Avatar
    Andrew
    Watsoia
    you can also get bog with a small amount of metal fibres in it. this is stronger than normal bog, and should be less prone to cracking.
    ...or just get someone who is good with a TIG to weld all the holes up.
  1. Better than bog?
    By squish_m8 in forum Offtopic Discussions
    Last Post: 20th May 2010, 10:45 PM
  2. Seam sealer/primer/bog q's
    By NIZLAH in forum Technical - Questions
    Last Post: 17th February 2009, 09:11 PM
  3. acceleration bog
    By #109 in forum Technical - Questions
    Last Post: 1st June 2008, 03:44 PM
  4. BOG...
    By riceburner in forum General Topics (No Technical Questions)
    Last Post: 22nd November 2007, 09:48 PM
