Alternator?
possibly not charging right or has some bad connection
gotta problem guys
car is having problem starting. racv checked it for the first time and the guy said its my choke problem and he got it started
today it had the same problem starting so i called them again
different guy came and said my headgasket's giving a problem
both different person and i dont know whats wrong with it
went to check the batts just now and the guy said the batt isnt the problem.
but when they jump my batt the car seem like it had more power to start like the cranking gets faster.
does any1 have this problem as well??
Alternator?
not really good in mechanics stuff tho
but ill try to look into it.
alternator's the one charging the batt is it?
but the lights and radio works fine
Yup, but it takes a very minimal amount of power to turn on lights and stuff. And quite a bit to crank the motor. But itll be a difinative noise if its not got much charge on the battery. Very slow moving noise..
If you can get it running id say just get it to the local mechanic
yeah it cranks but after a few tries it like slows down till it doesnt crank anymore
mech said the batt's okie
arghhh
