OK I am tied and I should know this.
I was thinking I should line the CAS up when the crank is at 10 degrees, and have the static timing in the MicroTech 10 degrees, and ignition timing at idle around 10-15 degrees in the microTech. Should this run?
It seams the Microtech makes the timing the same as static timing when cranking.
