Results 1 to 3 of 3
Thread: Ke30 Speedo Cable
    I was wondering what other cars have the same speedo cable as my 4 speed ke30 as i think mine is worn on one end which is causing my speedo to not work and i am looking to source anotehr cheap one
    thx
    -alex
    Jonathan
    Well if you want it cheap, a genuine one off a KE30 at the wrecker would have to be the cheapest! I think the KE55 one is a little different up at the speedo end. I think it works but just does not clip in the same from memory.
    At the gearbox end, most speedo cables will be the same. Except KE55 Auto will not be the same (holden gearbox).
    I would take a guess and expect the RA23 celica cable to be exactly the same. The same goes for most Toyotas of the era that were not loaded with australian parts. The KE20 one will not fit as it is different at the speedo end.
    Julz01
    ive got a few geniune nos toyota speedo cables at home, ill check what they are off and let you know if they are suitable ke30, ive got alot of ke parts
  1. Speedo Cable! Where?
    By Ktas in forum Technical - Questions
    Last Post: 2nd April 2012, 05:53 PM
  2. speedo cable
    By BLIPAE86 in forum Cars or Parts Wanted
    Last Post: 21st May 2009, 01:21 AM
  3. speedo cable
    By blu 86 in forum Technical - Questions
    Last Post: 18th July 2005, 10:13 PM
  4. speedo cable
    By jaqule in forum General Topics (No Technical Questions)
    Last Post: 1st January 1970, 11:00 AM
