Results 1 to 8 of 8
Thread: dot 5 fluid??
    Jul 2009
    on a mates 86.. used on the circut a bit.. has Hawk HP Plus pads on the front.. with ADM rotors and calipers.. the pads themselves don't fade.. but what is happening is the fluid (dot 3/4) goes to shit.. like the pedal goes to the floor after 3-4, 5 lap sprint sessions.. once the fluid is flushed and replaced the pedal is normal...
    the brake fluid were using is toyota genuine dot 3, but have tried some dot 4 also.. only reason i use the toyota dot 3 is because i have a full box of 500ml bottles.. like a dozen of them..
    would DOT 5 fluid be ok to use in this if it was flushed through and replaced?? it has new brake lines through out.. and master cyl and wheel cyls are not leaking etc.. all have been reced recently etc..
    opinions... it's definitly the fluid going to crap the car can sit for days after a race meeting and the pdeal will still feel the same shitty half dow to the floor.. but once replaced it's perfect..
    matty
    Elite rthy's Avatar
    Leo
    Tulla
    i had a similar problem with my twinky where the clutch would go to shite after 30mins of driving, making it hard to change gears even when the pedal was being crushed on the firewall...
    i ended up using some 500 to 600degree boiling point (or somecrap) brake fluid (dot5) and it seems to fix that problem quick smart
    Oldschool Member
    Feb 2007
    Dot 5 is silicone based and not compatible with dot3/4 systems. I think it eats the rubber seals.
    [taken from above link]
    Boiling Point Ranges Dry Boiling Point Wet Boiling Point
    DOT 3 205°C (401°F) 140°C (284°F)
    DOT 4 230°C (446°F) 155°C (311°F)
    DOT 5 260°C (500°F) 180°C (356°F)
    DOT 5.1 270°C (518°F) 191°C (375°F)
    Dot 5.1 apparently is safe on rubber systems, but I haven't seen them off shelf at your cheapo stores. There is high temp dot 4 (called super dot 4) rated up to 500-600 as Rthy says. Penrite is the cheaper one, then theres PBR and motul options.
    Be careful with Dot 5, on previous research, if it boils over it blackens and can solidify like goo. I would just double check that.
    B
    nsw
    glenwood
    aus
    RBF600 or similar (super dot 4)
    my brakes glow at night its great stuff.
    Ben.
    Elite rthy's Avatar
    Leo
    Tulla
    yea i think it was 4.1 or superdot 4 or something, it was the Penrite one
    Troy
    Baulkham hills
    Try Motul RBF600, AP Racing AP600 or Martini GS610
    All these are glycol based (ie. compatible with other dot 4, dot5.1 etc..)
    If you are still boiling fluid then you need to get bigger brakes.
    Rob
    Moorabbin
    DOT 5 will apparently go off much worse than DOT 4, once it goes beyond its max operating temp then it changes and doesnt change back wheras DOT 4 is supposed to go back to normal... Most good DOT 4 should be ok (marked 'racing' or high temp or whatever, the brands mentioned are all good).
    Your friend might want to get some temp paint (changes colour when gets to a certain temp) to see what his discs are doing (sounds like they are getting out of the pad operating range if they are doing that to the fluid). You could also try insulating the calipers from the pads with some sort of non conductive (and non flamable lol) material, try some ducting or as others have said upgrading.
    Jul 2009
    ill try the hi temp dot 4 glycol based stuff...
    yeh i know dot 5 was silicon based, and rubber doesn't like it very much so i was just makin sure about the info..
    the brakes seem very resistant to fade.. just the brake fluid seems to be shit for race applications.. hopefully this fixes some of the problem.. although a swap to rebuilt JDM calipers and JDM slotted rotors should help in the fade department.. i know it's not really an upgrade.. but it does make a difference keeping them cool!
  1. An insight into Brake Fluid
    Last Post: 28th August 2012, 06:55 PM
  2. Bendix High Performance Dot 3 and Dot 4 Brake Fluid
    Last Post: 27th October 2011, 11:07 AM
  3. trans fluid....amounts
    By Ade_Mc in forum Technical - Questions
    Last Post: 25th February 2011, 01:40 PM
  4. clutch fluid leaking
    By deanoo in forum Technical - Questions
    Last Post: 8th April 2007, 04:10 AM
  5. brake fluid loss
    By slippry in forum Technical - Questions
    Last Post: 23rd March 2007, 08:51 PM
