should fit flywheels are the same im pretty sure... if not use 16v flywheel
just got a question.. will a 200mm exedy clutch, exedy pressure plate and stock flywheel, fit a 20v?????
it was run behind a 4age 16v with t50????
Flywheel on the 20v are a bit bigger I'm pretty sure, only like 20mm I think, but I have a tendency to be wrong with sizing. 20v flywheels are a bit lighter and more grip surface for your clutch.
so could you use the 200mm clutch to fit a 20v with 20v flywheel?
stock 20V flywheel = 212mm
Do not use a 200mm clutch with this flywheel. However if you have a 200mm flywheel and clutch you can just bolt these to your 20V and everything will work fine.
All (8 bolt) 4A flywheels are interchangeable.
how ever its adviseable to stick with the 20valve flywheel right? going of the previous posts
20v flywheel is bigger and has more gripping area so in theory it's better.
16v = 200mm
20v = 212mm (215mm according to repco)
GZE = 224mm but will not fit inside the bellhousing of a T50.
most smallports are also 212mm..
7afe is 212mm
4afe is 200mm but both fe types are 6 bolt..
so a stock pbr clutch would be similar from a 7afe, to a ae92 4age..
