i changed to jdm acc pedal and it makes heel and toe easier
Ive had a set of Nardi 'look' pedals on for 2 years .. they look rad, have nice grippy rubber, and have never come loose as they have a mad fitting system/brackets... look identical apart from some branding.. cost $25 too..
ebay niggetz..
I have some pedals for you Hilton.. you can have them for free.
They cost $5 in the Phillipines. hehe
i'm with whoever said standard pedals and gearknobs. all aftermarket pedals i've sampled = shit
same here regarding A/M pedals and shifters... although the pedals I have are tha bomb.. and if your gona get a shifter, make sure its a screw on type.. ie: like the trust Grex ones and at the moment ebay has some decent threaded ones for cheap...
I have some Sparco carbon ones, they're pretty big but they're still good the only bad part is the grip came off them very quickly.
Foot pedal covers should have a 5cm gap between then to be safe.
If you must put them on, rivet them on or bolt them on your existing pedals.
Slipon ones have a habit of slipping off when you dont need em too, not good when you are downhilling, bye bye you die.
If you can avoid them, do so. no one looks at your foot pedals when your driving. spend the money on beter things, like tyres, oil, brakes.
Silver 86 Trueno Hatch.
AE86 4age gear for sale - http://www.ae86drivingclub.com.au/fo...eats-Ae86-gear
Side intrusion bars for your import - http://www.ae86drivingclub.com.au/fo...our-JDM-import
yea leave your standard pedals mate unless you can get the jdm accelerator, because obviously thats what takumi uses to heel and toe
