For sale: HKS 264 DEG 8.1mm lift Camshafts x2
Condition: Used, Good
Price and price conditions: $600 for the pair
Extra Info: Big port cams compatable with small port also. Will make a std 4age with cam gears over 160ps. Not needed as keeping my engine stock. I know borring.
Contact Details: PM ME
Delivery & Conditions of Delivery: Pick up only.
bump
shim under buckets and new valve springs recommended for running these cams?
aftermarket or stiffer valve spring is recommended. For shim under buckets at 8.1 lift not so, anything over 9.0mm, shim under buckets is highly recommended or a must
regarding the cam, what the power like in mid range?
thanks awang, good luck with sale asuka
well i may aswell make an offer, seeing as you havent had too much interest in these im gonna say $450 im on the gold coast and can pick up from brissy. cheers
I'll give u 500 if your interested?
HKS say to use HKS valve springs , just need to re shim head and it will give standard 4age with cam gears about 180-185ps at flywheel. They would make my engine about 200ps![]()
that sounds a bit optimistic but id be stoked with anything around 160ps. so offers have been considered?
