no power to ingitn switch... thanks for the help asked toolmods.. just gave smartass replies saying pay me 750 and ill do it all... but with the 4ac loom we took it all out with the engine... 2 plugs in the passenger side kick panel..
jace
as u might know i've just put a 4age out of an ae82 twinky into my ae82 sedan that had a 4A-C.. (shit motor) i have put motor in and its ready to be started, all wiring is in ( i think)... heres the catch.. no ignition.. headlights work, hazards work.. all the plugs of the 4age harness used the same plugs, i also used the fuse box out of the twinky.. help would be greatly appreciated... its been 1 week and i've ran out of ideas.. all fuseable links and fuses are fine!! there is power to all fuseable links near the battery.. when i turn the ignition nothing turns on at all.. radio, dash lights.. no red lights on cluster..
jace
jace
ok test for power at the signal wiring when the key was on start.. and it did not have any power.. where or how do i fix this so there is power to the signal wire to starter motor
jace
added u ..
jace
